CDR origIpAddr format
droberts
Beginner
Beginner
Hi I've been trying to figure out the format for this field in the CDR origIpAddr.  The documentation just says Integer but represents an IP v4 address.  Example values include
352737802  and -1759442934
dstaudt
An IP address by definition is a 32-bit value, and a 32-bit integer can represent.  If you want to convert this integer representation into something else, like the more familiar 'dotted octet' xxx.xxx.xxx.xxx, that will depend on what language you are using.  For example Java:
int ip  = ... ;
String ipStr =
String.format("%d.%d.%d.%d",
(ip & 0xff),
(ip >> 8 & 0xff),
(ip >> 16 & 0xff),
(ip >> 24 & 0xff));
From this thread: Java: convert int to InetAddress - Stack Overflow
This is an online decimal to dotted notation converter:
IP Converter: IP Conversion | IP Converters Hex, Binary, Decimal
Recognize Your Peers
