ciscoSupportField - Remove schema from node
notHappyCamper
Community Member
Am trying to set the ciscoSupportField when running addPhone
The xml being pushed in is
<soapenv:Envelope xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:ns=\"http://www.cisco.com/AXL/API/10.0\">
     <soapenv:Header/>
          <soapenv:Body>
               <ns:addPhone>
                    <vendorConfig>
                         <desktopClient>
                              <ciscoSupportField>configurationfile=jabber-config-CSF.xml</ciscoSupportField>
                         </desktopClient>
                    </vendorConfig>
this adds lots of extra xml schema info into the support field
<desktopClient xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/8.0">
     <ciscoSupportField xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/8.0">
          <ciscoSupportField>configurationfile=jabber-config-CSF1171.xml
<desktopClient>
need to strip all the schema info out to get this
<desktopClient>
     <ciscoSupportField>
</desktopClient>
Any ideas?
dstaudt
If the above is the XML you are sending in the request, where do you see the XML with the extra namespace stuff?  Is this present when you do a subsequent <getPhone>..?
The Cisco support admin sees the schema info in the ciscoSupportField field in his application (Have no access to that)
<desktopClient>
the only place it is specified in the API call is in the Soap Envelope
