Creating an Agent in HCS
vharishankar
I am new to HCS and HCM-F and trying to build a web application using which agents can be created in the HCS platform.
Should i need to use the CCDM Web service API's from my application to create an agent or use the HCM-F Web Service API's from my application to create an Agent. i went through the HCM-F API WSDL's and did not find any web methods that can be used to create an agent.
Any help is appreciated.
Hari
David Strong
From that description I would say CCDM API is what you need for the agent creation. HCM-F is more focused around the virtual infrastructure and associations to customer kit, and then the alarms around that.
