CUCM AXL addGateway - problems adding vendorConfig
I am able to add a gateway through AXL with python, but I am unable to get vendorConfig XML to get saved to the gateway config. Here is what the python fragment looks like when I build it.
                XML = "<_value_1><ModemPassthrough>Disable</ModemPassthrough><T3
8FaxRelay>Enable</T38FaxRelay><DtmfRelay>NTE-CA</DtmfRelay></_value_1>"
                tree = ET.fromstring(XML)
                gateway = {
                'domainName': 'XX.test.local',
                'description': 'XX gateway',
                'product': 'Cisco ISR 4321',
                'protocol': 'MGCP',
                'callManagerGroupName': 'Default',
                'units': {
                'unit': [],
                'vendorConfig': tree
It adds correctly, and I get this back.
{'domainName': 'XX.test.local', 'description': 'XX gateway', 'product': 'Cisco ISR 4321', 'protocol': 'MGCP', 'callManagerGroupName': 'Default', 'units': {'unit': [{'index': '0', 'product': 'ISR-2NIM-MBRD', 'subunits': {'subunit': [{'index': '1', 'product': 'NIM-1MFT-T1E1-E1', 'beginPort': '0'}]}}], 'vendorConfig': <Element 'vendorConfig' at 0x80a440350>}} {
    'return': '{8E7587A3-269D-2D8A-5B98-5CC0ACD11B38}',
    'sequence': None
but when I query it with getGateway, vendorConfig isn't set.
    'return': {
        'gateway': {
            'protocol': 'MGCP',
            'callManagerGroupName': {
                '_value_1': 'Default',
                'uuid': '{D13C4201-7802-11D3-BDF0-00108302EAD1}'
            'units': {
                'unit': [
                        'index': 0,
                        'subunits': {
                            'subunit': [
                                    'index': 1,
                                    'beginPort': 0
            'scratch': None,
            'vendorConfig': None,
            'versionStamp': '0000000000-c7a6c673-7479-46b0-839e-014d3d093963',
            'loadInformation': None,
            'uuid': '{873D02F6-5A74-4FA8-6DA7-115ACF8E9BD3}'
    'sequence': None
After I update the gateway through the GUI, it looks like this.
    'return': {
        'gateway': {
            'protocol': 'MGCP',
            'units': {
                'unit': [
                        'index': 0,
                        'subunits': {
                            'subunit': [
                                    'index': 1,
                                    'beginPort': 0
            'scratch': None,
            'vendorConfig': {
                '_value_1': [
                    <Element globalISDNSwitchType at 0x80ea09820>,
                    <Element switchBack at 0x80ea097d0>,
                    <Element switchBackDelay at 0x80ea0c320>,
                    <Element switchBackSchedule at 0x80ea0c410>,
                    <Element DtmfRelay at 0x80ea0c460>,
                    <Element ModemPassthrough at 0x80ea0c4b0>,
                    <Element CiscoFaxRelay at 0x80ea0c500>,
                    <Element T38FaxRelay at 0x80ea0c550>,
                    <Element rtpPackageCapability at 0x80ea0c5a0>,
                    <Element mtPackageCapability at 0x80ea0c5f0>,
                    <Element resPackageCapability at 0x80ea0c640>,
                    <Element prePackageCapability at 0x80ea0c690>,
                    <Element sstPackageCapability at 0x80ea0c6e0>,
                    <Element rtpUnreachableOnOff at 0x80ea0c730>,
                    <Element rtpUnreachableTimeout at 0x80ea0c780>,
                    <Element rtcpReportInterval at 0x80ea0c7d0>,
                    <Element simpleSdpEnable at 0x80ea0c820>
            'versionStamp': '1597420698-715c776e-736d-40e2-bfa6-cb9013092827',
    'sequence': None
I suspect that I am not using the right XML tag when I build the tree value. I have tried XML, vendorConfig, and _value_1 but none of those get stored correctly. What should I use?
5 Replies 5
dstaudt
I was able to get this working for <addPhone> using Python+Zeep for CUCM 12.5, see the 'axl_add_Phone_vendorConfig.py` sample in this project: CiscoDevNet/axl-python-zeep-samples
# Create an Element object from scratch with tag 'videoCapability' and text '0'
videoCapability = etree.Element( 'videoCapability' )
videoCapability.text = '0'
# The some config item Elements must be the child of a 'section' Element, e.g.:
#     <desktopClient>
#         <extendAndConnectCapability>0</extendAndConnectCapability>
#     </desktopClient>
desktopClient = etree.Element( 'desktopClient' )
extendAndConnectCapability = etree.SubElement( desktopClient, 'extendAndConnectCapability' )
extendAndConnectCapability.text = '0'
problemReportServerUrl = etree.SubElement( desktopClient, 'problemReportServerUrl' )
problemReportServerUrl.text = 'https://report.example.com'
# Append each top-level element to an array
vendorConfig = []
vendorConfig.append( videoCapability )
vendorConfig.append( desktopClient )
# Create a Zeep xsd type object of type XVendorConfig from the client object
xvcType = client.get_type( 'ns0:XVendorConfig' )
# Use the XVendorConfig type object to create a vendorConfig object
#   using the array of vendorConfig elements from above, and set as
#   phone.vendorConfig
phone[ 'vendorConfig' ] = xvcType( vendorConfig )
I took a more roundabout approach, though comparing the two, possibly the key is that vendorConfig needs to be an array of separate elements, whereas your example is a simple single element.  Possibly just wrapping that single element in an array might do it...
I'll have to beat on that a little more. That is more elegant that what I have done as a work-around. I made a brief try and copying what you did, but it didn't work right away.
gwname = input("Gateway Name: ")
gateway = {
'domainName': gwname,
sql = 'update mgcp set xml = \'<ModemPassthrough>Disable</ModemPassthrough><T38FaxRelay>Enable</T38FaxRelay><DtmfRelay>NTE-CA</DtmfRelay>\' where domainname = \'' + gwname + '\''
print(sql)
axl, history = axl_bind(server, acct, pw)
# Attempt AXL call
try:
    reply = axl.executeSQLUpdate(sql = sql)
# Check for error
# Return values based on request response
except Fault as err:
    if 'HTTP Status 401' in ET.tostring(history.last_received['envelope']).decode():
        print("Server Credential Error")
    else:
        print(err)
else:
    if reply["return"] is None:
        print("Unknown Result - Double Check Values")
    else:
        print("Update Success")
print(reply)
This is the error I got. Again, I just made a quick stab at it now. I am going to work on it some more since this method seems cleaner.
Traceback (most recent call last):
  File "gw_ins.py", line 87, in <module>
    reply = axl.addGateway( gateway )
  File "/usr/local/lib/python3.7/site-packages/zeep/proxy.py", line 45, in __call__
    kwargs,
  File "/usr/local/lib/python3.7/site-packages/zeep/wsdl/bindings/soap.py", line 119, in send
    operation, args, kwargs, client=client, options=options
  File "/usr/local/lib/python3.7/site-packages/zeep/wsdl/bindings/soap.py", line 68, in _create
    serialized = operation_obj.create(*args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/zeep/wsdl/definitions.py", line 215, in create
    return self.input.serialize(*args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/zeep/wsdl/messages/soap.py", line 74, in serialize
    self.body.render(body, body_value)
  File "/usr/local/lib/python3.7/site-packages/zeep/xsd/elements/element.py", line 231, in render
    self._render_value_item(parent, value, render_path)
  File "/usr/local/lib/python3.7/site-packages/zeep/xsd/elements/element.py", line 255, in _render_value_item
    return self.type.render(node, value, None, render_path)
  File "/usr/local/lib/python3.7/site-packages/zeep/xsd/types/complex.py", line 279, in render
    element.render(parent, element_value, child_path)
  File "/usr/local/lib/python3.7/site-packages/zeep/xsd/elements/indicators.py", line 242, in render
  File "/usr/local/lib/python3.7/site-packages/zeep/xsd/elements/any.py", line 126, in render
    self.validate(value, render_path)
  File "/usr/local/lib/python3.7/site-packages/zeep/xsd/elements/any.py", line 181, in validate
    self._validate_item(val, render_path)
  File "/usr/local/lib/python3.7/site-packages/zeep/xsd/elements/any.py", line 216, in _validate_item
    "See http://docs.python-zeep.org/en/master/datastructures.html"
TypeError: Any element received object of type 'Element', expected lxml.etree._Element or builtins.dict or zeep.xsd.valueobjects.AnyObject
See http://docs.python-zeep.org/en/master/datastructures.html#any-objects for more information
 Here is what I was trying to do
ModemPassthrough = ET.Element( 'ModemPassthrough' )
ModemPassthrough.text = 'Disable'
T38FaxRelay = ET.Element( 'T38FaxRelay' )
T38FaxRelay .text = 'Enable'
DtmfRelay = ET.Element( 'DtmfRelay' )
DtmfRelay .text = 'NTE-CA'
vendorConfig = []
vendorConfig.append( ModemPassthrough )
vendorConfig.append( T38FaxRelay )
vendorConfig.append( DtmfRelay )
gateway[ 'vendorConfig' ] = xvcType( vendorConfig )
I figured it out. I was using:
from xml.etree import ElementTree as ET
when I should have been using this from your code:
from lxml import etree
Now it works with this section:
ModemPassthrough = etree.Element( 'ModemPassthrough' )
T38FaxRelay = etree.Element( 'T38FaxRelay' )
DtmfRelay = etree.Element( 'DtmfRelay' )
vendorConfig = []
Thanks!
One last detail. This doesn't seem to negatively impact anything, but the contents of the XML column in the database look different right after I insert it with python than they do after I update it from the GUI. Here is what it looks like immediately after insert:
admin:run sql ccm select xml from mgcp where domainname = 'XX.test.local'
xml
<xml-fragment xmlns:ns0="http://www.cisco.com/AXL/API/8.0" xmlns:soap-env="http://schemas.xmlsoap.org/soap/envelope/">
</xml-fragment>
And here is what it looks like after an update from the GUI:
xml
<globalISDNSwitchType>4ESS</globalISDNSwitchType><switchBack>Graceful</switchBack><switchBackDelay>10</switchBackDelay><switchBackSchedule>12:00</switchBackSchedule><DtmfRelay>NTE-CA</DtmfRelay><ModemPassthrough>Disable</ModemPassthrough><CiscoFaxRelay>Disable</CiscoFaxRelay><T38FaxRelay>Enable</T38FaxRelay><rtpPackageCapability>Enable</rtpPackageCapability><mtPackageCapability>Disable</mtPackageCapability><resPackageCapability>Disable</resPackageCapability><prePackageCapability>Enable</prePackageCapability><sstPackageCapability>Enable</sstPackageCapability><rtpUnreachableOnOff>Enable</rtpUnreachableOnOff><rtpUnreachableTimeout>1000</rtpUnreachableTimeout><rtcpReportInterval>0</rtcpReportInterval><simpleSdpEnable>Enable</simpleSdpEnable>
It doesn't appear to make a difference at the moment, but this is just a lab system where I will never end up registering a real gateway.
Couldn't reproduce your observations on 12.5, but did add some vendorConfig items in the axl_addGateway.py sample...
