DoSyncLdap axl powershell
I am trying to clean up my code a bit and im trying to make a class of sort to be called with other functions. Here is the code:
Function Invoke-SoapRequest {
    param(
        [parameter(Mandatory)]$Body,
        [parameter(Mandatory)]$MethodName
$headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers.Add("SOAPAction", "CUCM:DB ver=10.5 $MethodName")
$headers.Add("Content-Type", "text/xml; charset=utf-8")
$headers.Add("Acc", "text/xml")
$headers.Add("Authorization", "Basic nonubusiness")
[System.Net.ServicePointManager]::ServerCertificateValidationCallback = {$true};
Invoke-RestMethod 'https://cucm/axl/' -Method 'POST' -Headers $headers -credential $pscred
function Sync-LDAP
    $AXL = @"
    <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5/">
        <soapenv:Header/>
            <soapenv:Body>
                <ns:doLdapSync>
                <name>LDAP</name>
                <sync>true</sync>
                </ns:doLdapSync>
            </soapenv:Body>
    </soapenv:Envelope>
Invoke-SoapRequest -Body $AXL -MethodName doLdapSync
Sync-LDAP
In my mind this should work as intended, but the powershell command is get malformed or something and this is not working at all. Any assistance would be appreicated.
Alexander Stevenson
Hi @danielmcgovern23187,
          I found a relevant discussion here on the forums regarding AXL, CUCM and doLdapSync:
Trigger LDAP sync via AXL API in CUCM 10
          Also:
All Search Results for 'doLdapSync' on these Cisco Community Forums
