getLineGroup - empty uuid for routePartitionName
stephan.steiner
This is what getLineGroup returns to me
<lineGroup uuid="{4AEB4622-84E4-CB12-2BA6-350E55C1E7A9}"><distributionAlgorithm>Broadcast</distributionAlgorithm><rnaReversionTimeOut>10</rnaReversionTimeOut><huntAlgorithmNoAnswer>Try next member; then, try next group in Hunt List</huntAlgorithmNoAnswer><huntAlgorithmBusy>Try next member; then, try next group in Hunt List</huntAlgorithmBusy><huntAlgorithmNotAvailable>Try next member; then, try next group in Hunt List</huntAlgorithmNotAvailable><members><member uuid="{7E0863F7-D066-7AB0-92FC-21E98688FE67}"><lineSelectionOrder>0</lineSelectionOrder><directoryNumber uuid="{4694AB3D-D9E4-E315-E79A-D345AA05B186}"><pattern>7881</pattern><routePartitionName>P_INTERNAL</routePartitionName></directoryNumber></member><member uuid="{A22F3767-F153-F992-75BE-01EF5198E5A8}"><lineSelectionOrder>1</lineSelectionOrder><directoryNumber uuid="{D5E4535C-3E1F-EA7A-D081-86A79A116570}"><pattern>7880</pattern><routePartitionName>P_INTERNAL</routePartitionName></directoryNumber></member></members><name>LG_HuntgroupTest</name><autoLogOffHunt>false</autoLogOffHunt></lineGroup>
Note that no member has an uuid for the route partition. There's no filtering of the return tags. Given that other commands do return the name/uuid combo I'm wondering why this isn't the case with this object.
6 Replies 6
jocreed
Hey Stephan,
Could you please submit the post you are using so we can have a better idea of why we are seeing what you are seeing?
Below is what I am getting when I perform this operation (CUCM ver. 10.5, utilizing SoapUI to submit request):
Post:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:getLineGroup sequence="?">
         <!--You have a CHOICE of the next 2 items at this level-->
         <name>LG_test</name>
         <!--<uuid>?</uuid>-->
         <!--Optional:-->
         <returnedTags>
            <!--Optional:-->
            <distributionAlgorithm>?</distributionAlgorithm>
            <!--Optional:-->
            <rnaReversionTimeOut>?</rnaReversionTimeOut>
            <!--Optional:-->
            <huntAlgorithmNoAnswer>?</huntAlgorithmNoAnswer>
            <!--Optional:-->
            <huntAlgorithmBusy>?</huntAlgorithmBusy>
            <!--Optional:-->
            <huntAlgorithmNotAvailable>?</huntAlgorithmNotAvailable>
            <!--Optional:-->
            <members>
               <!--Zero or more repetitions:-->
               <member uuid="?">
                  <!--Optional:-->
                  <lineSelectionOrder>?</lineSelectionOrder>
                  <!--Optional:-->
                  <directoryNumber>
                     <!--Optional:-->
                     <pattern>?</pattern>
                     <!--Optional:-->
                     <routePartitionName uuid="?">?</routePartitionName>
                  </directoryNumber>
               </member>
            </members>
            <!--Optional:-->
            <name>?</name>
            <!--Optional:-->
            <autoLogOffHunt>?</autoLogOffHunt>
         </returnedTags>
      </ns:getLineGroup>
   </soapenv:Body>
</soapenv:Envelope>
Response:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
   <soapenv:Body>
      <ns:getLineGroupResponse xmlns:ns="http://www.cisco.com/AXL/API/10.5">
         <return>
            <lineGroup uuid="{EA2432B4-655C-D640-40CA-551C044EA596}">
               <distributionAlgorithm>Circular</distributionAlgorithm>
               <huntAlgorithmNoAnswer>Try next member, but do not go to next group</huntAlgorithmNoAnswer>
               <huntAlgorithmNotAvailable>Stop hunting</huntAlgorithmNotAvailable>
               <members/>
            </lineGroup>
         </return>
      </ns:getLineGroupResponse>
   </soapenv:Body>
</soapenv:Envelope>
Christopher
Request and response as requested.
Request
  <soapenv:Header/>
  <soapenv:Body>
  <ns:getLineGroup sequence="10">
  <name>LG_Huntgroup Test</name>
  </ns:getLineGroup>
  </soapenv:Body>
</soapenv:Envelope>
Response:
<?xml version='1.0' encoding='UTF-8'?>
  <soapenv:Body>
  <return>
  <members>
  <member uuid="{95172383-279C-5489-D24A-0252E9FC217F}">
  </directoryNumber>
  </member>
  <member uuid="{169D2491-741D-7397-690C-111E8E4A826C}">
  </directoryNumber>
  </member>
  </members>
  </lineGroup>
  </return>
  </soapenv:Body>
</soapenv:Envelope>
I marked the routePartitionName of my two members in bold.. I think they are lacking the uuid tag.
By the way.. where did the sequence go in the reply? I've never really used it before - I assumed it was to correlate request and reply
npetrele
I don't know why it doesn't return the uuid, but you can always get it with getRoutePartition, searching by name.
stephan.steiner
Of course - I was merely pointing out an inconsistency. I'm not sure it's by design (in fact I'm quite convinced it is not) so in my book it smells like a bug that ought to be corrected.
I can speak with the engineers about it to see why or if the uuid was left off intentially or not
