getRoutePattern response missing destination and routePartitionName
Daniel Appleby
Hi All,
I am trying to use AXL on CUCM 10.5 to fetch data about a routePattern using getRoutePattern. Most properties are returned except complex ones like destination and routePartitionName.
Request Xml:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5">
    <soapenv:Header />
    <soapenv:Body>
        <ns:getRoutePattern>
  <pattern>12345</pattern>
  <returnedTags>
  <pattern/>
  <routePatitionName />
  <provideOutsideDialtone/>
  <destination><gatewayName /></destination>
  </returnedTags>
        </ns:getRoutePattern>
    </soapenv:Body>
</soapenv:Envelope>
The response I get back:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
<soapenv:Body>
<ns:getRoutePatternResponse xmlns:ns="http://www.cisco.com/AXL/API/10.5">
<return>
  <routePattern uuid="{DCF3D735-7E74-FD60-DBB1-474831916C13}">
  <routePartitionName/>
  <provideOutsideDialtone>false</provideOutsideDialtone>
  <destination/>
  </routePattern>
</return></ns:getRoutePatternResponse></soapenv:Body></soapenv:Envelope>
The destination and routePartitionName are missing but they are set for this routePattern in CUCM.
Any help getting these values to return would be much appreciated.
Thanks in advance.
-Daniel
npetrele
Good find.  I was able to reproduce the problem here.  I will file a defect for this.
Oddly enough it works when the routePartitionName is included in the search query
    <soapenv:Header />
    <soapenv:Body>
<routePatitionName>PT-Test </routePatitionName>
  <returnedTags>
  <pattern/>
  </returnedTags>
    </soapenv:Body>
</soapenv:Envelope>
That makes sense, now that I think of it.  A single line can have more than one route partition, depending on your setup. For example, I have a test line 7101 set up with two route partitions because the number is used in a hunt list and is assigned to a phone. The entry in the hunt list points to a different route partition than the one for the phone.  I can see that when I use the Admin UI and go to Call Routing->Route Plan Report.
So it makes sense that you'd need to specify the route partition in the search parameters to get the information you need for that line/route partition combo.  So this is probably not a bug at all.
could this be a remant of the old days where (iirc) you could run a lot of commands with non unique identifiers and still get a Response? The Documentation states that if you're going to select with pattern, routePartitionName, routeFilterName and under certain conditions, dialPlanName are also mandatory.
