how to create a phone cti port?
Sebastian74842
Hi, Since I can create a "CTI Port", I have searched and found nothing related. What lines do I have to create? How do I add the line?
dstaudt
CTI Ports are classed with all the 'regular' phone types (other than CTI Route Points), and are created using <addPhone>, which is nearly identifical to <addCtiRoutePoint> discussed previously.  I added a basic sample to the AXL Java Samples repo here: https://github.com/CiscoDevNet/axl-java-samples/blob/master/src/main/java/com/cisco/axlsamples/addPhone.java
hi, do you know how to upload audio for music on hold following the example you gave me above?
