How to remove between locations from Location using AXL
jdrinkwater
Trying to remove the between locations from the current location using AXL.
It seems you can only issue updateLocation request with <betweenLocations/> tag to delete all the locations from the both location then add the existing ones back.
Is anyone found the better solution for this?
dstaudt
Testing on my 11.5 system, the behaviour is definitely weird, and I think incorrect.  It appears that if you do <updateLocation>, anything in <betweenLocations> gets added to the existing list of <betweenLocations>, rather than replacing the list (as I would expect, and as AXL works in other areas.)
I've opened a defect to track/investigate this issue: CSCvo57112
You may be able to work around the issue by using <executeSqlQuery> - the relevant tables appear to be 'location' and 'locationmatrix'.
dstaudt
jdrinkwater
Thanks David!!
I will follow up with the status of the case.
