IM&P - How to turn on XMPP Federation Node Status using AXL ?
fabien.bonic
Level 5
Level 5
Hi all,
I need to turn "On" the XMPP Federation Node Status on a IM&P server (10.5) using an AXL request. I though it was possible using a SQL request but I don't found the table containing this option.
Any idea?
Fabien
dstaudt
Although IM&P now includes an API called 'Roster Management AXL-API' (with fairly limited functionality scope, i.e. add/renameContact), the IM&P system's undocumented 'AXL' service (corresponding to CUCM AXL) is not officially supported for 3rd party use.  The only recommended mechanism for controlling settings such as XMPP federation is via the admin UI.
Thank you for the answer. So there are no solution to change this value except through the admin UI? Is there a solution to read its value?
Fabien
