LLbmHubGroup schema does not match RLbmHubGroup
Jonathan Els
Level 5
Level 5
The LLbmHubGroup schema is the following:
<xsd:complexType name="LLbmHubGroup">
  <xsd:sequence minOccurs="0">
  <xsd:element maxOccurs="1" minOccurs="0" name="name" type="xsd:string"/>
  <xsd:element maxOccurs="1" minOccurs="0" name="description" type="xsd:string"/>
  <xsd:element maxOccurs="1" minOccurs="0" name="member1" type="xsd:string"/>
  <xsd:element maxOccurs="1" minOccurs="0" name="member2" type="xsd:string"/>
  <xsd:element maxOccurs="1" minOccurs="0" name="member3" type="xsd:string"/>
  </xsd:sequence>
  <xsd:attribute name="uuid" type="axlapi:XUUID"/>
</xsd:complexType>
We can compare this to the RLbmHubGroup schema:
<xsd:complexType name="RLbmHubGroup">
  <xsd:element maxOccurs="1" minOccurs="0" name="members">
  <xsd:complexType>
  <xsd:element maxOccurs="unbounded" minOccurs="0" name="member" type="axlapi:RProcessNodes"/>
  </xsd:sequence>
  </xsd:complexType>
  </xsd:element>
  </xsd:sequence>
</xsd:complexType>
For some reason,  the list response definition just removes the members detail in RProcessNodes
Can anyone explain this to me?  I think this is also a bug?
Paul Giralt
I suspect this is a performance optimization when doing the list and if you want the details, you need to query for the specific item.
Paul Giralt
OK, not the answer I wanted, but makes sense...
