PHP AXL Call no longer working
chad_meyer
Hey everyone,
I am picking up again on a project that has me using AXL requests into CUCM 11.5. Initially I had this working per Cisco's PHP AXL Quickstart guide, however that is now not working.  Doing some digging I found the common name of the cert was updated to use multi-san. So now instead of the CN of the cert being cucmpub.domain it now shows cucmpub-ms.domain.  My context variable is as follows, which I thought bypassed certificate checks:
$context = stream_context_create(array('ssl'=>array('allow_self_signed'=>true)));
This connection fails with a 'cannot connect to host'.  With these same values pointed to a different CUCM server we have in which the CN of the cert matches the hostname, my API is able to be called.  I have also tried defining the cafile of the tomcat cert, which also fails.
Any thoughts on how to get a connection?
Thanks in advance!
dstaudt
Your example would validate for a certificate where the certificate authority cert and the host cert are the same (self-signed), but I think you also need '
'verify_peer_name'=>true
to allow it to validate when the CN and host name are mismatched (even downloading and specifying the cert file won't work, since the names don't match.)
But...
  • Hopefully one of the SANs is in fact the host name..?  If not, that's very bad and should be corrected.
  • I'm not sure how/if PHP SOAPClient supports validating SAN certs - if you're using an older PHP version, you might try updating to something recent (maybe support was added..?)  If that doesn't work, you might try inquiring with the PHP community - hopefully there's a solution, or at least a bug report you can follow...
Thanks for the reply @dstaudt. I added the 'verify_peer_name' entry, however getting the same results.  The hostname is defined in the SAN entry and am running PHP 7.3.  I didn't see anything in the PHP docs that SAN checking but will reach out in a PHP community to see what insights they can provide.  Thanks.
