UCCert management API keeps returning 404 not found
aurelien.fasolo
I am trying to play a little bit with the CUCM certificate management API (Developer Support - UC Certificate Management API - Document - Cisco DevNet) but regardless of the API call, I always get 404 - not found response from the CUCM.
For example, the curl command hereafter (as recommanded in the getting started section) returns a 404 - not found
curl -k -X 'GET' -u "username:password" -H 'Content-Type: application/json' https://192.168.66.155/platformcom/api/v1/certmgr/config/snapshot/server
I am running a CUCM 12.5. To be noted that I have also tried with the PUB CUCM from the associated sandbox (DevNet Sandbox - Workspace - Lab Catalog - Collaboration 12.5 (cisco.com)). I have the same issue.
Has anyone manage to make the UCcert API work?
There is a note on the Cert API Overview page indicating it was introduced in v14.  Unfortunately the API was developed to address the lack of a supported automatable mechanism for UC host cert management in prior versions...
You may be able to accomplish some of the functionality by driving the CUCM CLI via a SSH API - i.e. in a 'screen-scraping' fashion.  While definitely not a supported - or necessarily stable or easy-to-use - programming interface, something like this sample may help in a pinch.
BjoernMartin
Hi. I have the same problem with version 12.
CUCM v14 works
aurelien.fasolo
Thanks for your answer. Is there any workaround for CUCM v12?
Indeed, I'm currently doing it over the CLI but it's sort of limited.
Thanks for the support and for mentionning the note, I did not see it when I looked at the documentation
