Problem with SOAP request on Serviceability API
Hi all,
CUCM 9.1
I am using SoapUI to validate the requests I send but I have a problem even with SoapUI
I send a request which I think is valid but the cucm answers with the following
HTTP/1.1 500 Internal Server Error
Set-Cookie: JSESSIONIDSSO=BB826706C518D24E79266716613307AC; Path=/; Secure; HttpOnly
Set-Cookie: JSESSIONID=F21D4361163FED25FB73E05DF5D20045; Path=/realtimeservice2/; Secure; HttpOnly
Set-Cookie: SoapSession.id=27222EF4C8E2DB5FA21413533658931
Content-Type: text/xml;charset=UTF-8
Transfer-Encoding: chunked
Date: Fri, 17 Oct 2014 08:14:17 GMT
Connection: close
Server:
<?xml version='1.0' encoding='UTF-8'?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server</faultcode><faultstring>unknown</faultstring><detail /></soapenv:Fault></soapenv:Body></soapenv:Envelope>
This is sent to the following URL
https://<cucm server>:8443/realtimeservice2/services/RISService70
I am not sure what is wrong with the request. Can somebody help me ?
Here it is
POST https://<cucm server>:8443/realtimeservice2/services/RISService70 HTTP/1.1
Accept-Encoding: gzip,deflate
SOAPAction: "selectCmDevice"
Content-Length: 841
Host: <cucm server ip address>:8443
Connection: Keep-Alive
User-Agent: Apache-HttpClient/4.1.1 (java 1.5)
Authorization: Basic Y2NtYWRtaW5pc3RyYXRvcjpVQzRRdWVudHIxJA==
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:soap="http://schemas.cisco.com/ast/soap">
   <soapenv:Header/>
   <soapenv:Body>
      <soap:selectCmDevice>
         <soap:StateInfo></soap:StateInfo>
         <soap:CmSelectionCriteria>
            <soap:MaxReturnedDevices>10</soap:MaxReturnedDevices>
            <soap:DeviceClass>Phone</soap:DeviceClass>
            <soap:Model>255</soap:Model>
            <soap:Status>Registered</soap:Status>
            <soap:NodeName></soap:NodeName>
            <soap:SelectBy>Name</soap:SelectBy>
            <soap:SelectItems>
            </soap:SelectItems>
            <soap:Protocol></soap:Protocol>
            <soap:DownloadStatus></soap:DownloadStatus>
         </soap:CmSelectionCriteria>
      </soap:selectCmDevice>
   </soapenv:Body>
</soapenv:Envelope>
Thanks!
Christos
I was too fast to post this time
Looks like I was missing some mandatory elements
Here is a working XML
   <soapenv:Header/>
   <soapenv:Body>
            <soap:SelectItems>
                <soap:item>
                  <soap:Item></soap:Item>
               </soap:item>
            </soap:SelectItems>
            <soap:Protocol>Any</soap:Protocol>
            <soap:DownloadStatus>Any</soap:DownloadStatus>
   </soapenv:Body>
</soapenv:Envelope>
   <soapenv:Header/>
   <soapenv:Body>
            <soap:SelectItems>
                <soap:item>
               </soap:item>
            </soap:SelectItems>
   </soapenv:Body>
</soapenv:Envelope>
