Problem with wsdl file on the RisPort
Hi Cisco,
I think there is a discrepancy between the definition of services as defined in the wsdl file and what the cucm server accepts
Version is 9.1
I am trying to use the SelectCmDevice. According to the wsdl it has a part called StateInfo and another one called CmSelectionCriteria
Both of them need to exist
Now if I go to CmSelectionCriteria I see that it contains 7 elements
MaxReturnedDevices
Class
Model
Status
NodeName
SelectBy
SelectItems
The mandatory ones are Status and SelectBy. The other can be omitted as there is nillable=True. The problem is with the last element 'SelectItems'
If the soap request contains it, the server returns the following
java.lang.ArrayIndexOutOfBoundsException
This error tells me that the soap request contains too many elements (and thus the array is bigger than what cucm expects)
I am using a client (suds) that is constructing the queries based on the wsdl files so that I don't have to bother with manually creating every request
Non working request
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns0="http://www.w3.org/2001/XMLSchema" xmlns:ns1="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns3="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ns2="http://schemas.cisco.com/ast/soap/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<SOAP-ENV:Header/>
<ns1:Body>
    <ns2:SelectCmDevice>
        <StateInfo xsi:type="ns0:string"></StateInfo>
        <CmSelectionCriteria xsi:type="ns2:CmSelectionCriteria">
            <ns2:MaxReturnedDevices xsi:type="ns0:unsignedInt">3</ns2:MaxReturnedDevices>
            <ns2:Class xsi:type="ns0:string">Phone</ns2:Class>
            <ns2:Model xsi:type="ns0:unsignedInt" xsi:nil="true"/>
            <ns2:Status xsi:type="ns0:string">Registered</ns2:Status>
            <ns2:NodeName xsi:type="ns0:string" xsi:nil="true"/>
            <ns2:SelectBy xsi:type="ns0:string">Name</ns2:SelectBy>
            <ns2:SelectItems xsi:type="ns2:SelectItems"/>
        </CmSelectionCriteria>
    </ns2:SelectCmDevice>
</ns1:Body>
</SOAP-ENV:Envelope>
Working Request
<SOAP-ENV:Envelope xmlns:ns0="http://schemas.cisco.com/ast/soap/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ns3="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns2="http://www.w3.org/2001/XMLSchema" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<SOAP-ENV:Header/>
    <ns1:Body>
        <ns0:SelectCmDevice>
            <StateInfo xsi:type="ns2:string"></StateInfo>
            <CmSelectionCriteria xsi:type="ns0:CmSelectionCriteria">
                <ns0:MaxReturnedDevices xsi:type="ns2:unsignedInt">3</ns0:MaxReturnedDevices>
                <ns0:Class xsi:type="ns2:string">Phone</ns0:Class>
                <ns0:Model xsi:type="ns2:unsignedInt" xsi:nil="true"/>
                <ns0:Status xsi:type="ns2:string">Registered</ns0:Status>
                <ns0:NodeName xsi:type="ns2:string" xsi:nil="true"/>
                <ns0:SelectBy xsi:type="ns2:string">Name</ns0:SelectBy>
        </ns0:SelectCmDevice>
    </ns1:Body>
You can see that the only thing missing is the SelectItems element. So either the wsdl is not correct or the cucm is not accepting the proper requests as far as I can tell
Christos
The WSDL is somewhat confusing in that there is an array type defined as 'ArrayofSelectItem', but the actual array elements are named 'item' (naming them 'SelectItem' would have been clearer, I think.)  However, the schema and implementation do work, the resulting request should look something like:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:soap="http://schemas.cisco.com/ast/soap">
   <soapenv:Header/>
   <soapenv:Body>
      <soap:selectCmDevice>
         <soap:StateInfo></soap:StateInfo>
         <soap:CmSelectionCriteria>
            <soap:MaxReturnedDevices>1000</soap:MaxReturnedDevices>
            <soap:DeviceClass>Any</soap:DeviceClass>
            <soap:Model>255</soap:Model>
            <soap:Status>Any</soap:Status>
            <soap:NodeName></soap:NodeName>
            <soap:SelectBy>Name</soap:SelectBy>
            <soap:SelectItems>
               <soap:item>
                  <soap:Item>IPCMRAEU5UCM5X7</soap:Item>
               </soap:item>
               <soap:item>
                  <soap:Item>IPCMRAEU5UCM5X8</soap:Item>
               </soap:item>
            </soap:SelectItems>
         </soap:CmSelectionCriteria>
      </soap:selectCmDevice>
   </soapenv:Body>
</soapenv:Envelope>
npetrele
I believe the SelectItems expects one or more items to be defined.  For example:
            <SelectItems xsi:type="soap:SelectItems" soapenc:arrayType="soap:SelectItem[]">
                  <soap:item>*</soap:item>
            </SelectItems>
This works, too:
            <soap:SelectItems>
            </SelectItems>
Hi Nicolas,
Thanks for the quick reply! I think you are referring to SelectItem element and not SelectItems (with an s in the end)
I take it from wsdl file
<complexType name="SelectItems">
     <complexContent>
          <restriction base="soapenc:Array">
               <attribute ref="soapenc:arrayType" wsdl:arrayType="tns:SelectItem[]"/>
          </restriction>
     </complexContent>
Am I right to understand that the SelectItems is an array of type SelectItem ?
And that SelectItem contains just string items ?
<complexType name="SelectItem">
<sequence>
     <element name="Item" type="xsd:string"/>
</sequence>
I am confused a bit. When I print the SelectItems type I get this
(SelectItems){
   _arrayType = ""
   _offset = ""
   _id = ""
   _href = ""
   _arrayType = ""
When I print SelectItem I get this
(SelectItem){
   Item = None
And finally when I print the CmSelectionCriteria I get this
(CmSelectionCriteria){
   MaxReturnedDevices = None
   Class = None
   Model = None
   Status = None
   NodeName = None
   SelectBy = None
   SelectItems =
      (SelectItems){
         _arrayType = ""
         _offset = ""
         _id = ""
         _href = ""
         _arrayType = ""
I see it contains already the SelectItems but not the SelectItem (without an s)
All the above is supposed to be constructed by the client based on the wsdl file. Is the file wrong or the client somehow constructs it wrongly ?
   <soapenv:Header/>
   <soapenv:Body>
            <soap:SelectItems>
               <soap:item>
               </soap:item>
               <soap:item>
               </soap:item>
            </soap:SelectItems>
   </soapenv:Body>
</soapenv:Envelope>
Thanks ! Since I don't have the skill to verify if the wsdl file is wrong (it looks ok from what I can tell) then I will have to assume that it's the client that malforms the query
In any case, I can workaround it, it's just that I want to avoid any manual intervention as much as possible
Christos
