Python AXL - Case Sensitive Problem
Jacob Webb
Level 3
Level 3
Does anyone know of a way to list a user without knowing the case?  Here's my example:
def check_user(user_name):
     user = active_cm.service.listUser({'userid': user_name},
          {'userid': '',
          'firstName': '',
          'lastName': ''})
     for each in user['return']['user']:
          print('Is this the correct user?\n',
               'User ID: ' + each['userid'] + '\n',
               'First Name: ' + each['firstName'] + '\n',
               'Last Name: ' + each['lastName'])
This works fine when I put in the correct case, but if I don't know it then it throws and error (TypeError: string indices must be integers) because the return is empty as seen below:
(reply){
   return = ""
dstaudt
I can't think of a way to make that work with listUser - it might be a useful enhancement to make some or all of the listXXX request string fields case-insensitive...
You can use executeSqlQuery to get the result you're looking for:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:executeSQLQuery>
         <sql>select userid from enduser where LOWER(lastname)=LOWER("LABuser1")</sql>
      </ns:executeSQLQuery>
   </soapenv:Body>
</soapenv:Envelope>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
   <soapenv:Body>
      <ns:executeSQLQueryResponse xmlns:ns="http://www.cisco.com/AXL/API/10.5">
         <return>
            <row>
               <userid>labuser1</userid>
            </row>
         </return>
      </ns:executeSQLQueryResponse>
   </soapenv:Body>
</soapenv:Envelope>
however there may be a (potential) significant performance impact from the LOWER(lastname) function, in that it may cause the query engine to do a full table scan on the userid/lastname fields, vs. using an index.  Would be good to test against a large data set (50K users).
dstaudt
   <soapenv:Header/>
   <soapenv:Body>
   </soapenv:Body>
</soapenv:Envelope>
   <soapenv:Body>
         <return>
            <row>
            </row>
         </return>
   </soapenv:Body>
</soapenv:Envelope>
