"Missing element commonPhoneConfigName" Error Message When Adding Phone via AXL
fdharmawan
Level 4
Level 4
Hi Guys,
Basically I want to add a phone device along with the user and line association. I managed to get it done using XML on Postman, but somehow when I 'translated' the code to Python, "zeep.exceptions.ValidationError: Missing element commonPhoneConfigName (addPhone.phone.commonPhoneConfigName)" appears when compiling the code. All other codes like adding new line, getting device info, etc are working normally. May I know what am I missing? I googled the error code but so far no luck. Thanks
fdharmawan
Level 4
Level 4
Somehow I managed to pass this problem by inserting the parameter but with no value ('commonPhoneConfigName': '') on the command.
fdharmawan
Level 4
Level 4
What CUCM Version are you using?
Hi Thedd,
It's 11.5
