Removing an Association of Device from a User
AR7
I have the following AXL syntax for removing all the associations of devices from the User:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
                <SOAP-ENV:Body>
                  <axl:updateUser xmlns:axl="http://www.cisco.com/AXL/API/11.5" sequence="12055">
                    <userid>john.doe</userid>
                   <associatedDevices>
                    </associatedDevices>
                  </axl:updateUser >
                  </SOAP-ENV:Body>
                </SOAP-ENV:Envelope>
I just keep the associated devices tag blank, and all the association is deleted. My problem is what if I have to remove a single association from a list of associatedDevices, how will the syntax be like.
And after removing the association will the ownerUserName in the Phone config be removed.
BjoernMartin
First check with getUser which Devices are associated with your enduser.
In my response you can see two device CSFBMARTIN and SEP000011112222.
Now I just want to assign my Jabber Device and remove the SEP000011112222 Device.
Following by an Update!
REQUEST:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:getUser sequence="?">
         <!--You have a CHOICE of the next 2 items at this level-->
         <userid>bmartin@rsc-lab.de</userid>
         <returnedTags uuid="?">
            <associatedDevices>
               <device></device>
            <lineAppearanceAssociationForPresences>
               <lineAppearanceAssociationForPresence uuid="?">
                  <laapAssociate></laapAssociate>
                  <laapProductType></laapProductType>
                  <laapDeviceName></laapDeviceName>
                  <laapDirectory></laapDirectory>
                  <laapPartition></laapPartition>
                  <laapDescription></laapDescription>
               </lineAppearanceAssociationForPresence>
            </lineAppearanceAssociationForPresences>
         </returnedTags>
      </ns:getUser>
   </soapenv:Body>
</soapenv:Envelope>
RESPONSE:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
   <soapenv:Body>
      <ns:getUserResponse xmlns:ns="http://www.cisco.com/AXL/API/11.5">
         <return>
            <user uuid="{2D887B79-6D9B-3521-470F-3F0B025D9146}">
               <associatedDevices>
                  <device>CSFBMARTIN</device>
                  <device>SEP000011112222</device>
                  <lineAppearanceAssociationForPresence uuid="{72D88797-F3FA-AFB6-AC98-7113B30DC138}">
                     <laapAssociate>t</laapAssociate>
                     <laapProductType>Cisco Unified Client Services Framework</laapProductType>
                     <laapDeviceName>CSFBMARTIN</laapDeviceName>
                     <laapDirectory>\+49211469951062</laapDirectory>
                     <laapPartition>glo_intern</laapPartition>
                     <laapDescription>CSF,Bjšrn Martin,2301062,DTTS GmbH</laapDescription>
                  <lineAppearanceAssociationForPresence uuid="{CE02488E-1A7C-1DD7-6508-578D45DE7F8F}">
                     <laapAssociate>f</laapAssociate>
                     <laapProductType>Cisco 9971</laapProductType>
                     <laapDeviceName>SEP000011112222</laapDeviceName>
                     <laapDirectory>\+49211469951662</laapDirectory>
                     <laapDescription>2311662_Bjoern Martin</laapDescription>
            </user>
         </return>
      </ns:getUserResponse>
   </soapenv:Body>
</soapenv:Envelope>
REQUEST Update:
   <soapenv:Header/>
   <soapenv:Body>
      <ns:updateUser sequence="?">
         <associatedDevices>
            <lineAppearanceAssociationForPresence>
      </ns:updateUser>
   </soapenv:Body>
</soapenv:Envelope>
