Start And Stop Services Using SOAP
tohsheenbazaz
Hi Guys
I have CUCM version 10.5.2.11900-3
I am using the control center web service, and intend to stop / start or restart service through a cron job.
As of now, I am just testing this API using the SOAPUI, and am have a little trouble.
I am able to get the list of services perfectly fine using the getStaticServiceListExtended
But when I try to stop a running CTI Manager service using the soapControlServicesEx , the server returns a fault. Not sure why. Has anyone faced this.
Have not looked any logs as of now.
Request:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:soap="http://schemas.cisco.com/ast/soap">
   <soapenv:Header/>
   <soapenv:Body>
      <soap:soapDoControlServicesEx>
         <soap:ControlServiceRequestEx>
            <soap:ProductId>CallManager</soap:ProductId>
            <soap:DependencyType>none</soap:DependencyType>
            <soap:ControlType>stop</soap:ControlType>
            <soap:ServiceList>
               <!--Zero or more repetitions:-->
               <soap:item>Cisco CTIManager</soap:item>
            </soap:ServiceList>
         </soap:ControlServiceRequestEx>
      </soap:soapDoControlServicesEx>
   </soapenv:Body>
</soapenv:Envelope>
Response:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
   <soapenv:Body>
      <soapenv:Fault>
         <faultcode>soapenv:Server</faultcode>
         <faultstring>unknown</faultstring>
         <detail/>
      </soapenv:Fault>
   </soapenv:Body>
</soapenv:Envelope>
If there is anything you can point out, I would appreciate that.
=BR
Tohsheen
tohsheenbazaz
Any pointers on this ?
I was able to reproduce this problem until I changed the <ControlType> value to 'Stop' (vs. 'stop').  The correct values are present in the WSDL, but the online documentation could be more clear here.
