urlopen error [dh key too small] with python suds client for perfmon api
zerocool443
So i am using this scripts that uses perfmon api to fetch counters/details from call manager.
Some details about the script.
Python 3.x
Libs: suds-jurko, ssl
API: perfmon api
The script works perfectly fine on my lab cucm. but when i test this with another labs it gives me following errors.
urllib.error.URLError: <urlopen error [SSL: SSL_NEGATIVE_LENGTH] dh key too small (_ssl.c:777)>
Code snippet:
from suds.client import Client
from suds.xsd.doctor import Import
from suds.xsd.doctor import ImportDoctor
import logging
import ssl
ssl._create_default_https_context = ssl._create_unverified_context
wsdl = 'https://10.106.79.98:8443/perfmonservice2/services/PerfmonService?wsdl'
location = 'https://10.106.79.98:8443/perfmonservice2/services/PerfmonService'
username = test
password = test
tns = 'http://schemas.cisco.com/ast/soap/'
imp = Import('http://schemas.xmlsoap.org/soap/encoding/',
'http://schemas.xmlsoap.org/soap/encoding/')
imp.filter.add(tns)
client = Client(wsdl, location=location, faults=False, plugins=[ImportDoctor(imp)], username=username,password=password)
perfmon_objects_1 = ['AnnunciatorResourceTotal', 'MOHTotalMulticastResources', 'MTPResourceAvailable',
'SWConferenceResourceAvailable', 'RegisteredHardwarePhones', 'TLSConnectedSIPTrunks', ]
res = client.service.perfmonCollectCounterData(node_name, 'Cisco CallManager')
print('CALL MANAGER Resources')
for node in res[1]:
counter_name=(str(node['Name'].split('\\')[4]))
if(counter_name in perfmon_objects_1):
print(counter_name)
print(str(node['Value']))
Chris Deren
Did you ever find a solution to this by any chance?
hey chris,
The code worked on py 3.4.
I was developing the script on py 2.7 earlier.
As per the understanding py 3.4 implementation of urlopen either ignores those alerts or doesn't use those key sharing algorithms.
