11-07-2014 05:05 AM
Our customer mentioned that through the gui, when they change a line - they must then register it. What api does this? Or does the UpdateLine implicity do this for us?
11-07-2014 07:49 AM
If all you want to do is update information about a line, then updateLine is all you need. I'm not sure what you mean by "register". If by "register" you mean associate the line with a phone, then you would specify line information in an addPhone or updatePhone AXL call.
11-12-2014 08:17 AM
Maybe it is Reset? Do you have to reset the line and/or phone after you update something on it to get the new setting to take affect?
11-12-2014 09:53 AM
Depending on what you change, yes, you need to do an applyPhone and sometimes a resetPhone and a restartPhone.
11-12-2014 03:49 PM
Is there any documentation with an explanation of what these do? I am in the Cisco Unified CM AXL Schema Reference to get formats and such…but there is no descriptions of what they do or when to use them.
Thanks!
Claire
11-13-2014 07:26 AM
There is no detailed documentation on what the AXL calls do. They're pretty self-explanatory. It also helps to use SoapUI to examine the AXL API. applyPhone is the equivalent to clicking "Apply Config" when you are editing a phone in CUCM web administration. resetPhone is the same as clicking "Reset" and restartPhone is the same as clicking "Restart" from the "Reset" dialog box.
