AddPhone XML, is there a way to use the DN instead of the UUID for it?
clairetaylor1
See below...dirn uuid - is there a way to use the directory number in this command instead of the uuid?
<axl:addPhone xmlns:axl="http://www.cisco.com/AXL/API/1.0" sequence="1">
<newPhone>
  <name>SEPF41FC26718CF</name>
  <lines>
    <line>
<index>1</index>
       <label>Dicks Test</label>
<display></display>
       <dirn uuid="1362B08C-0DF8-2548-ECC3-E4B8A3DEB45D"/>
       <ringSetting>Use System Default</ringSetting>
<consecutiveRingSetting></consecutiveRingSetting>
<dialPlanWizardId>0</dialPlanWizardId>
    </line>
  </lines>
  <model>Cisco 7945</model>
  <product>Cisco 7945</product>
  <protocol>SCCP</protocol>
  <protocolSide>User</protocolSide>
  <callingSearchSpaceName>CSS-NCOS 4 - National_International</callingSearchSpaceName>
  <class>Phone</class>
  <devicePoolName>Default</devicePoolName>
</newPhone>
</axl:addPhone>
npetrele
I think you want <pattern>, for example:
            <dirn>
              <pattern>12345678</pattern>
              <routePartitionName>Some Route Partition</routePartitionName>
            </dirn>
