Where to find CUCM AXL complete reference guide for all API
Mark Dugas
The AXL Developer Guide page (AXL Developer Guide - AXL - Document - Cisco DevNet) offers a few basic examples, but where is the complete documentation for all the API's - such as valid values for a device class for the listPhone API?  I have been unable to find it.  Thanks.
Mark
dstaudt
See the 'Schema Reference' for this kind of detail: https://developer.cisco.com/docs/axl-schema-reference/
Mark Dugas
Thanks for the reply.
I already have the schema, which lists all the elements, and I understand that.
What I do not have is a document that lists all valid values for querying an element, for example, in listPhone API, what are all the valid values for the element in Search Criteria.
Thanks.
The schema should show the allowed <SearchCriteria> elements for each requests, i.e. for <listPhone>:
Within each element, at least for strings, you can use a few wildcards.  My understanding is the AXL <listXXX> requests under the covers eventually result in a SQL query similar to: SELECT w FROM x WHERE y LIKE z
and 'z' is basically criteria element string.
For example:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/14.0">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:listPhone sequence="1">
         <searchCriteria>
            <description>%testdescription%</description>
         </searchCriteria>
         <returnedTags>
            <name/>
            <description/>
            <product/>
            <model/>
         </returnedTags>
      </ns:listPhone>
   </soapenv:Body>
</soapenv:Envelope>
is run as:
SELECT Device.pkid AS t0_pkid, Device.name AS t0_name, Device.description AS t0_description, Device.tkProduct AS t0_tkProduct, Device.tkModel AS t0_tkModel FROM Device WHERE my_lower(Device.description) LIKE "%testdescription%"
The supported wildcards for the LIKE clause come from the underlying CUCM datbase (Informix IDS): https://www.ibm.com/docs/en/informix-servers/14.10?topic=condition-like-operator
(afaik the escape character is '\')
