Bypass When Computer Is Offline (No Internet)
nathan-martins
Hi everyone, I'm facing an issue—or maybe it's just a missing configuration.
We have Duo installed on company computers, and the users have already enrolled in the Duo Mobile app. However, they haven't completed the offline access setup. So when a computer is offline, the user can still enter their company login and password, and Duo authentication is not prompted. This basically creates a kind of bypass.
I'm wondering if there's a configuration I'm missing? I couldn't find any policy setting that forces users to complete the offline enrollment.
Has anyone dealt with this before or has any suggestions?
Below is an image of the screen that prompts users to set up offline access, but they just click the “X” and skip it. I'd like to force users to complete the offline setup.
Thanks in advance!
DuoKristina
It sounds like you might have set the fail mode to "fail open" (allow login without MFA when offline) which isn't recommended if you only want users who set up offline access to be able to log in whilst offline.
https://duo.com/docs/rdp#offline-access-requirements
"Disable the Bypass Duo authentication when offline (FailOpen) option. If you enabled FailOpen during installation, you can change it in the registry."
https://duo.com/docs/rdp-faq#how-does-offline-access-in-duo-for-windows-logon-interact-with-fail-mode
"Users who have not activated offline access are subject to the fail mode setting e.g. if set to fail open, a user who did not activate offline access would be able to log in without completing Duo offline authentication. Disable "fail open" if you want to prevent users who did not activate offline access from logging in when the computer is offline."
ETA there is not a way to force users to complete offline setup today. Please contact your Duo Care team/account exec or Duo support to submit this as a feature request.
Duo, not DUO.
