Duo Integration with ISE for TACACS+ Device Administration with AD Users
Hi guys,
I need to know if is possible use DUO with ISE connected tu Azure AD to give access to our Network equipment using Tacacs+
i already test using duo with duo proxy+ise+ad on-premise, but now i need use ise with azure ad, the idea is not use a duo proxy
7 Replies 7
Antony GALLEZ
Hi @Patricio_Mansilla,
As far as I know, the only way to integrate ISE with Duo is through Radius and hence through the authentication proxy.
This is also stated in the Duo documentation:
To integrate Duo with your Cisco ISE, you will need to install a local Duo proxy service on a machine within your network. This Duo proxy server will receive incoming RADIUS requests from your Cisco ISE, contact your existing local LDAP/AD or RADIUS server to perform primary authentication, and then contact Duo’s cloud service for secondary authentication.
Antony
Jamie7
Can you please share how you use DUO for ISE Device Admin with AD
Jamie7
Thanks alot @Patricio_Mansilla, Appreciate your response.
Hi Guys,
I have the same query. Is it possible in the current version of ISE?
DuoKristina
This gal suggests taking a look at the Duo feature released in ISE 3.3 P1:
https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-33/221232-configure-ise-3-3-native-multi-factor-au.html
https://www.cisco.com/c/en/us/td/docs/security/ise/3-3/release_notes/b_ise_33_RN.html#concept_btq_mhd_lzb
This implements direct connectivity between ISE and Duo without Duo Authentication Proxy server deployment.
Duo, not DUO.
Hello Kristina,
Thanks a lot for your response. Does the direct integration have any limitations over the DUO Auth Proxy method?. Instead of the on-Premises AD, can we use the Azure AD along with the direct integration method?.
