Duo Network Gateway-Prerequisites
Ah15
Is Duo Network Gateway working with on-prem Active Directory ? or should we use SAML (Cloud Identity provider) as an authentication source?
raphka
Hi Ah15,
The authentication source for the DNG must be a SAML IDP.
However you can use Duo SSO as your SAML IDP with on prem AD as the authentication source.
raphka
Hi Ah15,
