Enable choose an authentication method
ShreeNiraula
How to enable choose an authentication method on RDP mode?
mkorovesisduo
Level 4
Level 4
Hi ShreeNiraula,
To select an authentication method after a push has been automatically sent, click Cancel and then select the method you would like to use.
To disable autopush on a system you have already installed Duo Protection for RDP on, you must modify the registry key described here.
Note that you can also configure whether autopush is enabled or disabled during installation.
mkorovesisduo
Level 4
Level 4
Hi ShreeNiraula,
