Protect RD Gateway with Yubikey token
omoyano
I configured my hardware token like this: https://duo.com/docs/yubikey
and assigned to user.
When launch my rdp session (user+password) can't connect. Yubiko Key doesnt work. Error to etablish connection. I need to do extra configuration?
In my rdp configuration file I have active:
  • Smart Cards or Windows Hello for Business
  • WebAuthn (Windows Hello or Security Keys)
For information Yubiko works fine with protected application Citrix or OWA (Browser with otp code)
And of course with Duo Mobile all works fine I can connect to rdp
My question is. It's possible to use Yubiko Key to protect RDP connection?
Thanks a lot
DuoKristina
You mention both RDP and RD Gateway in your post, so not sure which of those two Duo applications you are actually using.
YES - you can use a Yubikey OTP with Duo Authentication for Windows Logon https://duo.com/docs/rdp
NO - you cannot use a Yubikey OTP (or any other type of OTP token or passcode) with Duo for RD Gateway https://duo.com/docs/rdgateway
Duo, not DUO.
