TOTP Hardware Tokens
Clutz1
My organization bought some Duo D-100 tokens for our Duo protected application. I read that the Digipass GO 6 supported "time (TOTP) based (on demand)" algorithms. If we discontinue HOTP support permantely for our protected applications, will our Duo D-100s still be okay to use?
DuoKristina
Yes, the tokens will still work. The "Discontinue HOTP support permanently" option only determines which type of Duo Mobile app passwords the service will accept. The setting doesn't affect hardware tokens.
Duo, not DUO.
