ADsyncProxyOnPrem
Shawn.gaston1
Community Member
Hello hope all is well. we already have SSO AD auth proxy setup on a server. can we use that do do the cloud on prem ad sync just add another section to the proxy config page?
DuoKristina
Yes, you can use the same Duo Authentication Proxy server to run SSO auth and sync. Append the new [cloud] section for the sync to the existing authproxy.cfg file.
Duo, not DUO.
DuoKristina
Duo, not DUO.
pefect thanks i’ll mark as solved
