Delete and restore users manually created in DUO
a.maldonado
Hi!
I have a DUO production account to which the users were added manually to work with ISE and a DUO proxy. This setup worked and is still working fine.
Now, I upgraded ISE to the version that has DUO integrated so I can remove the proxy from the process. Unfortunately, the process fails at the last stage when I sync the security groups configured in ISE (previously imported from AD) to DUO. The Identity Sync returns a FAIL with No Data Found.
My suspicion is that because the users are already in the DUO account and were created manually, there must be some kind of conflict when ISE is trying to sync the groups with DUO. My question is, Is there a way to clear the users created in the DUO production account and if required put them all back again without having to cerate one by one again.
I opened a free DUO account and the process of setting up ISE with integrated DUO works fine and straightaway. It just does not want to do it with my production account. By the way, I remove from ISE, the configuration that works with the Proxy to avoid conflicts and from the Proxy the keys used for DUO. So to leave the proxy completely isolated but still the Identity Sync fails.
I will appreciate any help provided.
DuoKristina
The ISE team created this integration using our publicly-documented Duo Admin API and Auth API, and didn't provide us that much detail about the ISE operations using those APIs. My understanding is that their "sync" is just making GETs and POSTs to the Duo Admin API /admin/v1/users and /admin/v1/bulk endpoints. If your users were manually created in Duo prior to adding the ISE sync and have the same username values as in the directory you are syncing via ISE, there should be no issue with ISE updating the users via the API.
Is it possible your Duo users weren't created "manually" as in "click add user, type in username, save", but were created in Duo via AD Sync (through the Duo Authentication Proxy)? Admin API is unable to update groups or modify some user attribute values if they are still managed by a Duo AD sync. If you still have an AD Sync hanging out in your prod Duo account managing the users and groups that might be the issue. If you view a user in the Duo Admin Panel does it say it's managed by a sync? You need to delete the sync first, which reverts the sync-managed users and groups to unmanaged.
If you're still stuck you should open a case with TAC to route to ISE support, as they, and not Duo teams, are the SMEs for what their ISE sync operation is actually doing.
Duo, not DUO.
a.maldonado
@DuoKristina I am sorry for the late reply but it took us until the end of last year to figure out what was happening. There were two issues. the first one, as the accounts were added manually there were a number of accounts which had the same email address. For example, the admin account of each IT member had the same email address as the normal account but the most important was that the Sync button of ISE worked some times. We eventually raised a TAC case and they figured this out and solved by applying patch 4 of v3.3. Thank you for your help.
