Display which users accounts are set to 'Bypass'
oMurchu
Hello.
Is there a native report in DUO that will display which users accounts are set to ‘Bypass’?
Joe
@oMurchu You can see which users have been assigned “Bypass” status by logging into the Admin Panel and clicking Users on the left. Once you’re viewing the list of users, click the “Bypass Users” tab to filter the view to only show users with that status. You can then use the “Export” options to download that filtered list of users.
Duo, not DUO.
Amy2
Level 5
Level 5
Hi Joe, and welcome to the Duo Community! It’s not a report necessarily, but I think this might be what you’re after. You can display a list of bypass codes, including which users have them, by selecting Users in the left sidebar of the Duo Admin Panel then Bypass codes. See the docs on Viewing and Deleting Bypass Codes for more info
Duo, not DUO.
