Phone alias - import users
RJS3
Community Member
Does anyone know if it is possible to set the phone alias name when performing a user import via CSV?
I dont see this option in the list of CSV fields.
Rich.
DuoKristina
No, there is no way to import the optional free-form text label for a phone via CSV. If you need to assign names to phones in Duo en masse, you can use the Admin API /phones endpoint to programmatically update the name property for each one.
Duo, not DUO.
Amy2
Level 11
Level 11
Hi Rich, can you clarify what you mean by phone alias name? Are you referring to a secondary phone number such as a forwarding number that connects to a single device? There is no phone alias field, as you’ve noted, but you can add multiple phone numbers to a single user by including columns for phone1, phone2, etc. upon CSV import.
DuoKristina
Duo, not DUO.
