Invalid credentails error while logging using SSO
Vishal6
Level 6
Level 6
Hi All,
I have configure DUO Admin panel login using 2FA with SSO hosted by Duo. All the configuration has been done referring below document but im facing an invalid credentials error while logining using SSO but same is getting sucessfull if i login using password.
Please help me
Vishal6
Level 6
Level 6
any suggestion to rectify and solve this issue
Hi Vishal, I recommend contacting Duo Support to troubleshoot this issue. They’ll be able to look at the logs to see the exact reason why login is failing and advise you as to the steps you’ll need to take to resolve this.
rnewcomer1
Community Member
Duo is Cisco...
