Merging 3 users into 1
NogNeetMachinaal1
Community Member
Team,
See also attached image:
These 3 usernames are actually the same user; only with different accounts for different applications. Two questions:
(1) - Is there a way to prevent this from happening (and how)?
(2) - Is there a way to merge these into one username (and how)?
Thanks - Will
Amy2
Level 11
Level 11
Hi Will,
Yes, you can use Username Aliases to allow for multiple login names for a single user.
The Username Aliases Migration Guide explains the cleanup process for an environment that already has multiple usernames for a single employee:
  1. Identify the primary username format to be used going forward. (typically sAMAccountName)
  2. Delete secondary usernames in Duo that will soon become aliases to the primary username.
  3. Add secondary usernames in Duo as aliases to primary usernames.
There are, of course, caveats to each of the above steps based on how you’ve chosen to import or add users to Duo. Please check out the full guide, and feel free to follow up here with additional questions!
Amy2
Level 11
Level 11
Hi Will,
Thanks Amy.
I will give this a try in the coming weekend - but only after completing the MS-AD integration by creating custom elements for these aliasses.
Kind regards - Will
Amy2
Level 11
Level 11
P.S. You might find our new education platform, Level Up, really valuable. It’s free, and the courses take around 15 to 20 minutes to complete. It’s still in the beta stage currently. You can get more info on the courses here and sign up to participate here.
@Tab_Berger leads that program, so he can share more info and answer any questions you might have
Thanks Amy.
Just registered for the beta on the courses.
Cheers - Will
