ssh/telnet with acl
knanyhy011
hello friends I have made an acl to restrict vlans 102 , 103 to use telnet & ssh  and permit valn 100 the result I have done this but the problem is with vlan100 I can use telnet & ssh with router br1 & br2 but hq router I could not  the ping  with hq unreachable what is the problem?
BR1#sh ru
Building configuration...
Current configuration : 2429 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname BR1
enable secret 5 xxx
no ip cef
no ipv6 cef
username cisco secret 5xxx
ip domain-name ccna.com
spanning-tree mode pvst
interface GigabitEthernet0/0/0
no ip address
ip ospf 20 area 0
duplex auto
speed auto
interface GigabitEthernet0/0/0.100
encapsulation dot1Q 100 native
ip address 192.168.100.1 255.255.255.240
ip ospf 20 area 0
interface GigabitEthernet0/0/0.102
encapsulation dot1Q 102
ip address 192.168.100.65 255.255.255.224
ip helper-address 192.168.100.6
ip ospf 20 area 0
ip access-group 100 in
interface GigabitEthernet0/0/0.103
encapsulation dot1Q 103
ip address 192.168.100.33 255.255.255.240
ip ospf 20 area 0
interface GigabitEthernet0/0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Serial0/1/0
ip address 10.10.10.2 255.255.255.252
ip ospf 20 area 0
clock rate 2000000
interface Serial0/1/1
ip address 10.10.10.6 255.255.255.252
ip ospf 20 area 0
ip access-group 110 out
interface Vlan1
no ip address
shutdown
interface Vlan102
mac-address 00d0.ba41.0d01
no ip address
router ospf 20
log-adjacency-changes
default-information originate
ip classless
ip flow-export version 9
access-list 100 deny tcp any host 10.10.10.5 eq 22
access-list 100 deny tcp any host 10.10.10.5 eq telnet
access-list 100 deny tcp any host 10.10.10.1 eq 22
access-list 100 deny tcp any host 10.10.10.1 eq telnet
access-list 100 deny tcp any host 192.168.100.1 eq 22
access-list 100 deny tcp any host 192.168.100.1 eq telnet
access-list 100 deny icmp any 192.168.100.0 0.0.0.15
access-list 100 permit ip any any
access-list 100 permit tcp any any
access-list 110 permit tcp any host 100.1.1.3 eq www
access-list 110 permit tcp any host 100.1.1.3 eq 443
access-list 110 permit tcp any host 100.1.1.2 eq smtp
access-list 110 permit tcp any host 100.1.1.2 eq pop3
access-list 110 deny tcp any any
line con 0
line aux 0
line vty 0
no login
transport input none
line vty 1 4
password cisco
login
line vty 5 15
password cisco
login
end
20 Replies 20
sorry friend for being late
BR1#sh ru
Current configuration : 2635 bytes
version 15.4
hostname BR1
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
no ip cef
no ipv6 cef
username cisco secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
no ip address
ip ospf 20 area 0
duplex auto
speed auto
ip ospf 20 area 0
ip ospf 20 area 0
ip ospf 20 area 0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
ip ospf 20 area 0
clock rate 2000000
ip ospf 20 area 0
interface Vlan1
no ip address
shutdown
interface Vlan102
no ip address
router ospf 20
ip classless
ip access-list extended SSH-TELNET-ACCESS
permit tcp 192.168.100.0 0.0.0.15 any eq 22
permit tcp 192.168.100.0 0.0.0.15 any eq telnet
deny tcp any any eq 22
deny tcp any any eq telnet
permit ip any any
line con 0
line aux 0
line vty 0
access-class SSH-TELNET-ACCESS in
no login
line vty 1 4
password cisco
login
line vty 5 15
password cisco
login
end
BR1#
BR1#sh ip rou
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 10.10.10.5 to network 0.0.0.0
10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
C 10.10.10.0/30 is directly connected, Serial0/1/0
L 10.10.10.2/32 is directly connected, Serial0/1/0
C 10.10.10.4/30 is directly connected, Serial0/1/1
L 10.10.10.6/32 is directly connected, Serial0/1/1
O 10.10.10.8/30 [110/128] via 10.10.10.1, 00:03:57, Serial0/1/0
[110/128] via 10.10.10.5, 00:03:57, Serial0/1/1
192.168.100.0/24 is variably subnetted, 7 subnets, 4 masks
C 192.168.100.0/28 is directly connected, GigabitEthernet0/0/0.100
L 192.168.100.1/32 is directly connected, GigabitEthernet0/0/0.100
C 192.168.100.32/28 is directly connected, GigabitEthernet0/0/0.103
L 192.168.100.33/32 is directly connected, GigabitEthernet0/0/0.103
C 192.168.100.64/27 is directly connected, GigabitEthernet0/0/0.102
L 192.168.100.65/32 is directly connected, GigabitEthernet0/0/0.102
O 192.168.100.128/26 [110/65] via 10.10.10.1, 00:03:57, Serial0/1/0
O*E2 0.0.0.0/0 [110/1] via 10.10.10.5, 00:03:57, Serial0/1/1
Thank you for the configuration of BR1. I believe that I see the problem. Traffic to HQ goes out interface S0/1/1. That interface has an acl applied: ip access-group 110 out. What does this acl do?
All of its permits and denies are specific to tcp. Remembering that in an acl there is an implicit deny any at the end we see that any icmp traffic going to HQ will be denied.That is why your ping and tracert are failing.
Rick
Really friend thank you very very much
I am glad that our suggestions have been helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
 I did what you said exactly I  removed any ACL added to interface
You were told us that you removed all the ACL and failed ?
ip ospf 20 area 0
ip access-group 110 out   <<- you have still this ?
BB
Friend use
Router ospf 100
Network 0.0.0.0 0.0.0.0 area 0
In all router and l3SW
MHM
