Cisco Catalyst 3650 2 ISP vlan to remote office and address-table learning disabled on vlans
dboevets
Good day!
I have 2 Catalyst 3650 in stack (role intervlan routing)
#show version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.06E
And 2 ISPs provide service VLAN to remote office - VLAN ID the same 3524 and configured like mode access.
1-st ISP works, bun when I try to connect second ISP - doesn't work.
Before turn on port of 2 ISP I shut down port 1 ISP.
Configuration Catalyst 3650
Interface GigabitEthernet1/0/1 (before connect ISP-2 I shutdown this port)
description ISP-1
switchport access vlan 3524
switchport mode access
spanning-tree portfast
Interface GigabitEthernet1/0/2 (and no shutdown this)
description ISP-2
shutdown
#show ip interface brief
Vlan3524 192.168.3.1 YES manual up up
Remote switch
C3560 Software (C3560-IPBASEK9-M), Version 15.0(2)SE11
Vlan3524 192.168.3.41 YES NVRAM up up
#show spanning-tree vlan 3524
Interface Role Sts Cost Prio.Nbr Type
Gi0/1 Desg FWD 4 128.1 P2p
Gi0/2 Desg FWD 4 128.2 P2p
Interesting fact when I change Catalyst 3650 to another (3560) switch ports between ISPs works.
Configuration this switch the same
interface GigabitEthernet0/1 (ISP1)
interface GigabitEthernet0/2 (ISP2)
May be reason in that
On 3650 (in production)
#show mac address-table learning
Learning disabled on vlans:
And I can't turn in on
(config)#mac address-table learning vlan 3524
doesn't help - learning steel disabled.
maybe its normal for 3650 in stackwise?
Perhaps there is an assumption of what is the reason.
dboevets
And when I turn on int 1/0/2 (IPS2) I see mac of vlan interface on remote switch int vlan 3524, but can't ping in (192.168.3.41) and hosts connected to this switch.
There is issue with stp'
ISP is not allow stp bpdu and hence the both port is FWD which must be one FWD and other BLK'
If the ISP is same ask them if you can use PO or not?
MHM
