Egress cos marking on 7600 ES20G card
tomasimatel
Hi all, one of our network providers demands that all frames going through their systems be marked with cos S-tag value 0, everything else is dropped.
So, we need to set that mark on packets leaving our 7600, but we are having a hard time configuring QoS on it. We are trying this config:
class-map match-all todos
match any
policy-map cos0
class todos
set cos 0
interface TenGigabitEthernet4/0/0
 no ip address
 no mls qos trust
interface TenGigabitEthernet4/0/0.101
 encapsulation dot1Q 2031 second-dot1q 101
 ip address 10.0.58.29 255.255.255.252
But when I issue the command service-policy:
Router(config-if)#int te4/0/0.101
Router(config-subif)#service-policy output cos0
Queueing must be defined in class-default in a flat policy on this interface
I've searched for help using class-default but couldn't get it to work, could somebody please throw some light on it? Thanks
Tomas
Hello
Thanks for the information. This kind of configuration is not supported on ES20 linecard:
http://www.cisco.com/c/en/us/td/docs/routers/7600/install_config/ES20_config_guide/es20-config-guide/bald_qos.html#wp1374723
Marking policy in the egress direction is only supported with another queueing action in the class-default policy on the ES20. below is a sample config
match any
policy-map cos0
class todos
set cos 0
class class-default
shape average 100000
 no ip address
 no mls qos trust
Hope this answers your question.
Vinit
PS: Please mark the question as answered if your query has been answered.
--Vinit
Vinit Jain
Could you please share the show version | in image and show module 4 command output.
Vinit
--Vinit
Hi Vinit, here is the info you asked, thanks and regards.
Router#show version | in image
System image file is "sup-bootdisk:c7600s72033-adventerprisek9-mz.153-1.S.bin"
Router#show module 4
Mod Ports Card Type                              Model              Serial No.
  4    2  ESM20G                                 7600-ES20-10G3CXL  JAE1139XYYK
Mod MAC addresses                       Hw   Fw            Sw           Status
  4  001b.d588.b040 to 001b.d588.b0bf  1.1   12.2(33r)SRB  15.3(1)      Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  4  ESM20G Distributed Forwardi 7600-ES20-D3CXL    JAE114522ZM  1.0    Ok
 4/0 1x10GE XFP Port             7600-ES20-2X10G    JAE1145214G  1.0    Ok
 4/1 1x10GE XFP Port             7600-ES20-2X10G    JAE1145214G  1.0    Ok
Mod  Online Diag Status
  4  Pass
 4/0 Pass
 4/1 Pass
Hello
match any
policy-map cos0
class todos
set cos 0
class class-default
 no ip address
 no mls qos trust
Vinit
--Vinit
Thanks Vinit, that did the trick, we'll try tomorrow night to see if it works against our provider equipment.
Just one more doubt, is there a way to make CoS marking work on LAN cards like WS-X6704-10GE? Thanks
Tomas
