08-21-2013 04:07 PM
Hi Guys;
i need some help configuring two way active management protocol on ME 3600x devices running 15.2.2 IOS. The details of this protocol are listed at:http://www.cisco.com/en/US/docs/ios-xml/ios/ipsla/configuration/15-2s/sla_twamp.html
Here i sthe sample configuration that i am using:
Device> enable Device# configure terminal Device(config)# ip sla server twamp Device(config-twamp-srvr)# exit Device(config)# ip sla responder twamp Device(config-twamp-ref)# end
My question is whether we "have to" configure the server and responder on the same device. I have configured it as:
ip sla responder ip sla responder twamp timeout 300
And it does not seem to work.
Any help would be greatly appreciated!!!
cheers
04-16-2015 12:27 PM
I think some of these commands could help you:
show ip sla standards
show ip sla twamp connection
show ip sla twamp session
show ip sla twamp standards
, timer inactivity, timeout (twamp)..
05-07-2015 10:14 PM
Hello Jalal
please refer to the CCO doc:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipsla/configuration/xe-3s/sla-xe-3s-book/sla_twamp.html#GUID-1B9ED57D-44F8-49B7-81DE-94A49109F497
It mentions that "Each IP SLAs TWAMP responder is both a TWAMP server and a session-reflector." Thus the server and responder has to be configured on the same device. This is also mentioned in the same CCO doc shared above.
Hope this helps.
Vinit
