10-26-2015 03:38 AM
Hi Experts,
I am trying to create point to point EVC between 3600 and asr 920 using L2TPV3. Plan is to transfer between two client sites stp, vlan, cdp, lldp etc.. Is it possible between these two platforms using L2TPV3?
I know this is possible by EoMPLS.
Solved! Go to Solution.
11-01-2015 05:00 PM
Yes, the control plane is working but not the data plane. The below CCO documentation clearly says L2tpv3 encapsulation is not supported on ASR920 router:
http://www.cisco.com/c/en/us/td/docs/routers/asr920/hardware/chassis/guide/ASR920-Chassis-SW/T1-E1_Ifc_Module.html#pgfId-1187202
Hope this answers your question.
Vinit
PS: Please mark the question as answere if your query has been resolved. Also please rate useful posts.
11-01-2015 10:06 AM
Hello
L2TPv3 with EVC is not supported on ASR920. Infact, L2TPv3 is not supported at this point on ASR920 at all.
So, i believe what you are trying to achieve is not an option.
Vinit
PS: Please mark the question as answered, if your query has been answered.
11-01-2015 02:29 PM
Hi Vinit,
Would you please send me a link of the data sheet of ASR920. I could not able to locate this whether L2tpV3 is supported on ASR920. I tried to create a tunnel between 2811 and ASR920 and the tunnel looks up but could not able to make the data communication between the CPE devices.
ASR920
LABTESTPE2#
pseudowire-class CPE2
encapsulation l2tpv3
sequencing both
ip local interface Loopback0
interface GigabitEthernet0/0/6
no ip address
media-type auto-select
negotiation auto
no keepalive
xconnect 3.3.3.3 10 encapsulation l2tpv3 pw-class CPE2
LABTESTPE2#show l2tp session brief
L2TP Session Information Total tunnels 1 sessions 1
LocID TunID Peer-address State Username, Intf/
sess/cir Vcid, Circuit
3209013104 1416467998 3.3.3.3 est,UP 10, Gi0/0/6
LABTESTPE2#
LABTESTPE2#show l2tp tunnel state
L2TP Tunnel Information Total tunnels 1 sessions 1
LocTunID RemTunID Local Name Remote Name State Last-Chg
1416467998 8924 LABTESTPE2 LABTESTPE3 est 2d16h
LABTESTPE2#
11-01-2015 05:00 PM
Vinit
