OSPF flaps on interface
Beacon Bits
Level 4
Level 4
Hi Guys,
How do I check or command would tell me that OSPF neighborship drops.
Scenario:
I have few routers in network and running OSPF including Juniper and Cisco.
I can see DR (Cisco-3560) adjacency dropped from looking at other Juniper routers running OSPF in the same Broadcast Domain.
Now I'm on cisco and need to find out why OSPF adjacency dropped by Cisco SW.
rcmcdermott11
Frequent Visitor
Frequent Visitor
run 'debug ip ospf adj' so that you can view adjacencies build or tear down.
You can refer to this doc for troubleshooting steps. http://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/12151-trouble-main.html
While this one explains neighbor states
http://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/13685-13.html
Vinit Jain
Hello Shariq
Could you paste the show log output which shows the OSPF flap. Is it due to hold timer expiry or too many re-transmissions? Is the flapping happening continuously? Are there any drops on the interface (show interface <>)
The OSPF flap could be due to several reasons and if its a production network then running a debug might not be a good idea. Once you share the above information, we can further investigate.
Vinit
--Vinit
Ganesh Hariharan
Hi Guys,
Scenario:
Hi ,
Show ip ospf neighbour can give brief detail of neighbour OSPF issue.
check out the below links for more information details..
http://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/13688-16.html
http://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/13699-29.html
Hope it Helps..
-GI
Rate if it Helps..
