Hi Guys
If this is the wrong forum, my apologies.
I have a problem with an ADSL implementation. This is the Scenario , Laptop--- ADSL Modem--- AXH 2500 (Gig interface -- Gig Interface to 65k (sup 720)---MPLS Core-- 7303 BRAS
I am using PPPoE from the Laptop, connect an ethernet cable to the ADSL Modem that connects to the AXH 2510 .... as explained above.
My problem is the modem gets an IP address through PPPoE and the laptop connect to the internet fine, but if i start another modem connection on a different port through the same AXH 2510, it will take approximately 10 mins to get an IP address from the BRAS.
I cant have 2 modems to connection at the same time, i have checked the authentication from the radius server, it allows only one session per username but i still get the same problem even when i use a different username. The BRAS is the one allocating the IPs to the ADSL modems
Any ideas why it takes 10 mins to get an IP address and another Session ?
thanks in Advance
MM
