QOS on ME3400
pbenin
I?d like to highlight a problem we have configuring "Priority with Police" on a CiscoME3400 switch.
Following the indications in the configuration guide, once the service policy is applied to the interface on the switch the following error occurs:
class-map match-all GOLD
match ip dscp ef
class-map match-all BE
match ip dscp default
class-map match-all BRONZE
match ip dscp af21
class-map match-all SILVER
match ip dscp af11
policy-map LLQ
class GOLD
police cir 512000
priority
class SILVER
shape average 256000
class BRONZE
bandwidth 1000
policy-map SHAPING-OUT
class class-default
shape average 2000000
service-policy LLQ
ME3400_amps(config-pmap-c)#INT FA0/3
ME3400_amps(config-if)#Speed 10
ME3400_amps(config-if)#Duplex Full
ME3400_amps(config-if)#SERvice-policy OUtput SHAPING-OUT
QoS: Configuration failed. The configured rate is not achievable in hw within 1
% of configuration.
Closest value(s) are: 526315 bps, 500000 bps
The error does not occur while modifying the bandwidth in the policy map (for example to 256Kbps).
Similar errors have occurred during configurations which involve Class Based Shaping (QoS Parent-Child).
Are there specific indications or calculations for defining bandwidth parameters?
Look forward to receiving any suggestions on resolving these problems.
Thanks.
doddsb
Here is the answer from TAC when I asked the same question in Jan 07.
The error message can be explained by the fact that Hardware interface shaping granularity is (1-16/N) times the line rate where N=17...64000.
For example for Gigabit the shape rates would become: 58.8M =(1-16/17)x1G, 111.1M, 157.9M, 200.0M, 238.1M, 272.7M, 304.3M, 333.3M, ..., 999.6M, 999.7M, 999.8M =(1-16/64000)x1G.
For 100M interface this mean that minimum is about 6M.
In other words, the low end granularity is very coarse but the high end granularity is very fine. This is actually due to the hardware architecture, meaning also that this is something that cannot be changed.
The error message suggests you the closest value permitted:
"Closest value(s) are: 526315 bps, 500000 bps"
With these values the configuration will be accepted.
