6PE TCP Problem
Imtiyaz95
Hello everyone,
As a part of my university project i was given to implement MPLS 6PE on Gns3. I've done my configuration and the routing seems fine. I can ping Site 1 from site 2 and vice versa. I tried to ping UDP and TCP over the MPLS however i'm facing an issue for the tcp part. I get connection time out. Can someone help me please?PE1Unicast.PNGPE2UnicastSummary.PNGMPLS.png
rais
Level 7
Level 7
Your diagram shows no IPv6 addresses on sites. Make sure both PEs are getting routes from each other.
You can use wireshark on the end hosts to troubleshoot TCP.
HTH.
