Adding a Connection on MGX 8850 (with PXM-1E)
melkomy
Dear all,
I've MGX 8850 [ with PXM-1E (with 8 E3) and RPM-PR (NPE400) processor ] .....It's acting as an ATM edge-LSR in our cell-mode MPLS network
(This network is based on MGX 8850 with RPM-PR acting as ATM edge-LSRs and the BPX 8600 with LSC 7200 acting as the ATM LSR)
The problem is that I'm facing difficulties in adding connections between the PXM-1E (slave) and RPM-PR (Master).
1- RPM-PR IOS ver is 12.2(11)T2
2- PXM ver is 3.0(20.0)
3- The steps I follow for PXM-1E config are
a- upln 2.1
b- cnfln -e3 2.1 -len 30 -clk 2
c- addport 1 2.1 80000 80000 0 1
80000 ----->guaranteeRate in cells/sec
80000------> maxRate in cells/sec
0------------> sctId -- SCT file ID between 0 and 255, for default file use 0
1------------> ifType -- 1: uni 2: nni 3: vnni 4: vuni 5: evuni 6: evnni
d- TOTO.7.PXM.a > dsplns
Line Line Line Line Length OOF AIS Valid Alarm
Num State Type Lpbk (meters) Criteria cBitsCheck Intvls State
2.1 Up e3g832adm NoLoop 0 N/A N/A 96 Clear
e- TOTO.7.PXM.a > dspports
ifNum Line Admin Operational Guaranteed Maximum sctID ifType VPI MI
NVPI MAXVPI IMA
State State Rate Rate Conf./InUse (VNNI, (E
VUNI, (EVUNI, GRP
VUNI) E
VNNI) EVNNI)
1 2.1 Up Up 80000 80000 0/ 0 =Def UNI 0
f- addpart 1 4 4 100 100 100 100 0 255 1 65535 1000 2000
1-----> If Number -- number between 1 and 31
4-----> Partition Number -- Partition Identifier between 1 and 20
4-----> Controller Number -- Controller Identifier between 1 and 254
cntrlrIds 2 and 3 are reserved for PNNI and LSC respect
100----> Egr guaranteed % Bandwidth -- units:0.0001% of interface bandwidth
100----> Egr max % Bandwidth -- units:0.0001% of interface bandwidth
100-----> Ing guaranteed % Bandwidth -- units:0.0001% of interface bandwidth
100-----> Ing max % Bandwidth -- units:0.0001% of interface bandwidth
0--------> Minimum VPI Value -- number between 0 and 4095(0..255 for UNI interface
255----> Maximum VPI Value -- number between 0 and 4095(0..255 for UNI interfac
1-------> Minimum VCI Value -- number between 1 and 65535
65535-----> Maximum VCI Value -- number between 1 and 65535
1000----> Guaranteed number of conns -- number between 0 and 27000
between 10 and 13500 for PXM1E-16-T1E1
2000---->Max. number of conns -- number between 10 and 27000
g- TOTO.7.PXM.a > dspparts
if part Ctlr egr egr ingr ingr min max min max min max
Num ID ID GuarBw MaxBw GuarBw MaxBw vpi vpi vci vci conn conn
(.0001%)(.0001%)(.0001%)(.0001%)
h-TOTO.7.PXM.a > addcon
Err: Mandatory argument required.
Syntax: addcon ifNum vpi vci serviceType mastership
g- addcon 1 4 0 1 2
1-----> ifNum -- interface number (1..31)
4 ----> vpi -- vpi (UNI: 0..255 | NNI: 0..4095)
0------> vci -- vci: VCC (1..65535); VPC (0)
1------> serviceType -- cbr1(1) | vbr1rt(2) | vbr2rt(3) |
vbr3rt(4) | vbr1nrt(5) | vbr2nrt(6) |
vbr3nrt(7) | ubr1(8) | ubr2(9) |
2-----> mastership -- m (1) | s (2)
ERR: Error sending pass up message
I'd like to know what and why this error appear to me while i'm adding the connection ....wht's wrong??
Plz can anyone advise??
Komy
gmarogi
Level 5
Level 5
This release note document talks about the features and limitations of the hardware and release that you are using. Check if it helps in solving your problem :
http://www.cisco.com/univercd/cc/td/doc/product/wanbu/8850px45/relnote/30208850.htm
