ASR9K-ASR1K EoMPLS PW
volia.net
I have simple hub and spoke topology with ASR9K used as a hub and ASR1K's as spokes. ASR9K configured for l2vpn domain:
interface Loopback0
ipv4 address x.x.a.144 255.255.255.255
l2vpn
bridge group group_name
  bridge-domain bd441
   neighbor x.x.x.147 pw-id 441
   neighbor x.x.y.127 pw-id 441
   neighbor x.x.z.40 pw-id 441
   routed interface BVI441
Two of ASR1K connected works fine, but x.x.x.147 (IOS XE 3.5.0) still shows VC status down.
Here is detailed debug outputs and configuration from x.x.x.147:
mpls label range 16000 1048575
mpls ldp router-id Loopback1 force
mpls ip
interface Loopback1
ip address x.x.x.147 255.255.255.255
interface TenGigabitEthernet0/1/0.441
encapsulation dot1Q 441
xconnect x.x.a.144 441 encapsulation mpls
interface TenGigabitEthernet1/0/0.997
encapsulation dot1Q 997
ip address x.x.g.194 255.255.255.252
mpls ip
router ospf 1
router-id x.x.x.147
redistribute connected subnets
network x.x.g.192 0.0.0.3 area 0
ASR1K#show mpls l2transport vc 441 detail
Local interface: Te0/1/0.441 up, line protocol up, Eth VLAN 441 up
  Destination address: x.x.a.144, VC ID: 441, VC status: down
    Output interface: none, imposed label stack {}
    Preferred path: not configured
    Default path: no route
    No adjacency
  Create time: 00:01:54, last status change time: 00:01:54
  Signaling protocol: LDP, peer x.x.a.144:0 up
    Targeted Hello: x.x.x.147(LDP Id) -> x.x.a.144, LDP is UP
    Status TLV support (local/remote)   : enabled/supported
      LDP route watch                   : enabled
      Label/status state machine        : remote ready, LndRru
      Last local dataplane   status rcvd: No fault
      Last BFD dataplane     status rcvd: Not sent
      Last local SSS circuit status rcvd: DOWN(not-forwarding)
      Last local SSS circuit status sent: Not sent
      Last local  LDP TLV    status sent: None
      Last remote LDP TLV    status rcvd: No fault
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local unassigned, remote 16887
    PWID: 4563
    Group ID: local unknown, remote 47
    MTU: local unknown, remote 1500
    Remote interface description: Access PW
  Sequencing: receive disabled, send disabled
  Control Word: Off (configured: autosense)
  VC statistics:
    transit packet totals: receive 0, send 0
    transit byte totals:   receive 0, send 0
    transit packet drops:  receive 0, seq error 0, send 0
ASR1K(config-subif)# no xconnect x.x.a.144 441 encapsulation mpls
ASR1K(config-subif)# xconnect x.x.a.144 441 encapsulation mpls
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: FSM init LndRnd
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: Dataplane : No fault
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: FFD       : No fault
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: AC status DOWN(not-forwarding)
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: Provisioned
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: Evt provision, idle -> provisioned
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: . Provision vc
Jan 12 14:49:25.644 EET: AToM LDP[x.x.a.144, 441]: LDP OPEN request
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: . NMS: VC oper state:  DOWN
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: . NMS:     err codes:    no-fwdg
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: SYSLOG: VC is DOWN, PW Err
Jan 12 14:49:25.644 EET: AToM LDP[x.x.a.144, 441]: Signaling peer-id of VC changed to x.x.a.144
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: Evt remote ready, provisioned -> remote ready
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: . Receive remote vc label binding, instance 1
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: . Adjacency : No fault
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: .. S:Evt ADJ up in LndRnd
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: .. S:Evt dataplane clear fault in LndRnd
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: . Check if remote connected
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: .. Remote label is ready
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: .... S:Evt remote ready, LndRnd -> LndRrd
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: .... S:Evt remote up, LndRrd -> LndRru
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: .... S:Act send SSS(UP)
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: .....  [no service]
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: .... S:Evt ADJ up in LndRru
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: .. Yes, connected
Jan 12 14:49:25.644 EET: AToM LDP[x.x.a.144]: Hello adj created with local address 0.0.0.0
Jan 12 14:49:25.644 EET: AToM LDP[x.x.a.144]: Opening session, 1 clients
Jan 12 14:49:25.644 EET: ldp-trgtnbr: x.x.a.144 -> x.x.a.144 Req active by client, MPLS AToM Circuit
Jan 12 14:49:25.644 EET: ldp-trgtnbr: Created avl tree for vrf default
Jan 12 14:49:25.644 EET: ldp-trgtnbr: x.x.a.144 allocated
Jan 12 14:49:25.644 EET: ldp-trgtnbr: x.x.a.144 Set peer start; flags 0x10
Jan 12 14:49:25.644 EET: ldp: ldp start; tbl 0
Jan 12 14:49:25.644 EET: ldp-trgtnbr: x.x.a.144 Defer peer cleanup; cleancnt 1
Jan 12 14:49:25.644 EET: ldp-trgtnbr: x.x.a.144 Set peer finished; flags 0x1F
Jan 12 14:49:25.644 EET: ldp-trgtnbr: x.x.a.144 ref count incremented to 1
Jan 12 14:49:25.644 EET: AToM LDP[x.x.a.144]: Session is up
Jan 12 14:49:25.644 EET: AToM LDP[x.x.a.144, 441]: LDP open
Jan 12 14:49:25.644 EET: AToM LDP[x.x.a.144, 441]: LDP UP
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: Evt ldp up in remote ready
Jan 12 14:49:25.644 EET: AToM[x.x.a.144, 441]: . Take no action
As for me VC still down becouse local SSS circuit still down.
I try to compare two debug outputs from this one and working ASR1K and see that's in work case session continues with suc
Jan 12 14:10:59: AToM MGR [x.x.a.144, 441]: Receive SSS STATUS(UP)
Jan 12 14:10:59: AToM MGR [x.x.a.144, 441]: . AC status UP
Jan 12 14:10:59: AToM MGR [x.x.a.144, 441]: ... S:Evt local up, LndRru->LnuRru
Jan 12 14:10:59: AToM MGR [x.x.a.144, 441]: .. Event local ready, state changed from remote ready to establishing
Jan 12 14:10:59: AToM MGR [x.x.a.144, 441]: .... Alloc local binding
What "SSS" mean, why it has status down and how to fix it?
ASR1K#show int TenGigabitEthernet 0/1/0.441
TenGigabitEthernet0/1/0.441 is up, line protocol is up
Thanks for any ideas
rsimoni
since nobody answered and the required level of troubleshooting is quite high I suggest you open a TAC case for this (you can do this directly from CSC)
Riccardo
Vinit Jain
from the logs I see the following:
1) There is no local MTU learnt. Could you please configure a MTU value on the local interface. You may configure a service instance on the router and then assign a MTU value to that service instance. this shall help to sync up the MTU between the ASR9k and the ASR1k
2) There is no local label seen. The above may be the cause for the same.
Please check and let me know if that helps.
Vinit
--Vinit
