ASR9K MTU 14 byte adjustment on Ethernet and OSPF
s.lachica
Configuring mtu 9230 in ASR9K and mtu 9216 on CE router - will this make the ospf adjacency not go up?
Thanks!
CCIE (R&S) #27666 CCSI HP MASE
rais
Level 7
Level 7
Correct.
Better to use BGP instead.
Thanks.
Jose Jara
Level 3
Level 3
No, but you have different options:
1. Change the MTU value
2. Maintain the MTU , but adjust the IP MTU on the ASR9K to 9216
3. Configure mtu ignore
Hope this helps,
Jose.
