Authentication Fail?
Danilo Dy
I'm having problem connecting my router to the sp.
I turned on debug ppp auth and debug ppp neg. Below are the debug output, can anyone help to determine what is the problem?
Oct 10 14:51:16.674: Vi1 AUTH: Timeout 1
Oct 10 14:51:16.674: Vi1 PAP: Using hostname from interface PAP
Oct 10 14:51:16.674: Vi1 PAP: Using password from interface PAP
Oct 10 14:51:16.674: Vi1 PAP: O AUTH-REQ id 107 len 29 from "username"
Oct 10 14:51:26.690: Vi1 AUTH: Timeout 2
Oct 10 14:51:26.690: Vi1 PAP: Using hostname from interface PAP
Oct 10 14:51:26.690: Vi1 PAP: Using password from interface PAP
Oct 10 14:51:26.690: Vi1 PAP: O AUTH-REQ id 108 len 29 from "username"
Oct 10 14:51:36.706: Vi1 AUTH: Timeout 3
Oct 10 14:51:36.706: Vi1 PAP: Using hostname from interface PAP
Oct 10 14:51:36.706: Vi1 PAP: Using password from interface PAP
Oct 10 14:51:36.706: Vi1 PAP: O AUTH-REQ id 109 len 29 from "username"
Oct 10 14:51:46.690: Vi1 PAP: I AUTH-NAK id 109 len 26 msg is "Authentication failed"
Oct 10 14:51:46.694: Vi1 LCP: I TERMREQ [Open] id 4 len 4
Oct 10 14:51:46.694: Vi1 LCP: O TERMACK [Open] id 4 len 4
Oct 10 14:51:46.694: Vi1 PPP: Sending Acct Event[Down] id[131]
Oct 10 14:51:46.694: Vi1 PPP: Phase is TERMINATING
Oct 10 14:51:46.698: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
Oct 10 14:51:46.706: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
Oct 10 14:51:46.722: Vi1 LCP: State is Closed
Oct 10 14:51:46.722: Vi1 PPP: Phase is DOWN
Oct 10 14:52:08.706: Vi1 PPP: Phase is DOWN, Setup
Oct 10 14:52:08.710: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
Oct 10 14:52:08.714: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Oct 10 14:52:08.714: Vi1 PPP: Treating connection as a callout
Oct 10 14:52:08.714: Vi1 PPP: Phase is ESTABLISHING, Active Open
Oct 10 14:52:08.714: Vi1 PPP: Authorization NOT required
Oct 10 14:52:08.714: Vi1 PPP: No remote authentication for call-out
Oct 10 14:52:08.718: Vi1 LCP: O CONFREQ [Closed] id 1 len 10
Oct 10 14:52:08.718: Vi1 LCP: MagicNumber 0x132A0FF2 (0x0506132A0FF2)
Oct 10 14:52:08.722: Vi1 LCP: I CONFACK [REQsent] id 1 len 10
Oct 10 14:52:08.722: Vi1 LCP: MagicNumber 0x132A0FF2 (0x0506132A0FF2)
Oct 10 14:52:10.702: Vi1 LCP: I CONFREQ [ACKrcvd] id 2 len 18
Oct 10 14:52:10.702: Vi1 LCP: MRU 1492 (0x010405D4)
Oct 10 14:52:10.702: Vi1 LCP: AuthProto PAP (0x0304C023)
Oct 10 14:52:10.702: Vi1 LCP: MagicNumber 0x8478E237 (0x05068478E237)
Oct 10 14:52:10.706: Vi1 LCP: O CONFNAK [ACKrcvd] id 2 len 8
Oct 10 14:52:10.706: Vi1 LCP: MRU 1500 (0x010405DC)
Oct 10 14:52:10.710: Vi1 LCP: I CONFREQ [ACKrcvd] id 3 len 18
Oct 10 14:52:10.710: Vi1 LCP: MRU 1500 (0x010405DC)
Oct 10 14:52:10.710: Vi1 LCP: AuthProto PAP (0x0304C023)
Oct 10 14:52:10.710: Vi1 LCP: MagicNumber 0x8478E237 (0x05068478E237)
Oct 10 14:52:10.710: Vi1 LCP: O CONFACK [ACKrcvd] id 3 len 18
Oct 10 14:52:10.714: Vi1 LCP: MRU 1500 (0x010405DC)
Oct 10 14:52:10.714: Vi1 LCP: AuthProto PAP (0x0304C023)
Oct 10 14:52:10.714: Vi1 LCP: MagicNumber 0x8478E237 (0x05068478E237)
Oct 10 14:52:10.714: Vi1 LCP: State is Open
Oct 10 14:52:10.714: Vi1 PPP: Phase is AUTHENTICATING, by the peer
Oct 10 14:52:10.714: Vi1 PAP: Using hostname from interface PAP
Oct 10 14:52:10.714: Vi1 PAP: Using password from interface PAP
Oct 10 14:52:10.714: Vi1 PAP: O AUTH-REQ id 110 len 29 from "username"
Oct 10 14:52:20.706: Vi1 AUTH: Timeout 1
Oct 10 14:52:20.706: Vi1 PAP: Using hostname from interface PAP
Oct 10 14:52:20.706: Vi1 PAP: Using password from interface PAP
Oct 10 14:52:20.706: Vi1 PAP: O AUTH-REQ id 111 len 29 from "username"
Oct 10 14:52:30.722: Vi1 AUTH: Timeout 2
Oct 10 14:52:30.722: Vi1 PAP: Using hostname from interface PAP
Oct 10 14:52:30.722: Vi1 PAP: Using password from interface PAP
Oct 10 14:52:30.722: Vi1 PAP: O AUTH-REQ id 112 len 29 from "username"
attrgautam
Level 10
Level 10
Is it possible to show the config at both ends. There can be many reasons for Auth failure. What is the auth mechanism u r trying ?
