bridge-domain interface in Cisco IOS-XR
siblirayhan
Hello Everyone,
Hope all of you are doing fine. Recently I'm trying to make router routed interface into bridge interface so that I can send packet from PC1 to PC2 via same broadcasting bridge domain. I used iox-xr router for the LAB. My configuration is also given below. But still can't send packet from PC1 to PC2.
Both switch router connected port configured as trunk port. And PC connected ports are configure as access port with vlan 10. Please check my configuration and let me know is there my mistake ?
>>>>>>>>>>>>>>>>>>>>>Router Configuration<<<<<<<<<<<<<<<<<<<<<<<<<
interface GigabitEthernet0/0/0/0.10 l2transport
encapsulation dot1q 10
interface GigabitEthernet0/0/0/1.10 l2transport
interface BVI1
ipv4 address 192.168.0.1 255.255.255.240
l2vpn
bridge group CustomerA
bridge-domain bridge-domain1
mtu 8000
routed interface BVI1
end
Albertt
Hello, Seems good configuration, introduce the rewrite ingress tag pop 1 symmetric on each interface,Sometimes  it's hard to emulate L2 protocols. Try to use Cisco XRV 9000 instead of XRv and if you still face same issu, configure interfaces in access, computers directly to router and remove switchs from topology for troubleshooting.
16 Replies 16
check below
MHM
I already added. But still not getting ping PC1 to PC2 or BVI1 interface IP.
Found 3 AC up. I'm confused about below message. Am I getting any mac from my sub-interfaces ?
can I see the config of trunk in SW
MHM
Here added both switches configuration.
Use trunk instead of using access port in SW
Still now not solved. Now Router and PC both connected port configured as Trunk port. Below given configuration.
description Connected to Router
switchport mode trunk
media-type rj45
negotiation auto
interface GigabitEthernet0/1
description Connected to PC2
media-type rj45
negotiation auto
check below
MHM
As your instruction configuration done. In switch I found only PC mac, not getting mac from router side.
Similary from router I found only my own router BVI interface mac, not getting any mac from switch/PC.
RP/0/0/CPU0:R1#show l2vpn forwarding bridge-domain mac-address location 0/0/CP$
Sat Oct 12 14:11:02.055 UTC
Mac Address Type Learned from/Filtered on LC learned Age Mapped to
02c2.175a.a401 routed BD id: 0 N/A N/A N/A
RP/0/0/CPU0:R1#
Interface configuration on router.
share below if above config not work
show l2vpn bridge-domain group MHM bd-name MHMdomain
Here is given my current configuation and your asking report.
interface BVI1
l2vpn
flooding disable
mtu 8000
interface GigabitEthernet0/0/0/2
Sorry why you use flood disable??
MHM
Sorry for the late reply. Now I removed flooding disable option. But issue still remain. My existing os was XRv.  Now I decided to try this full configuration with XRv 9000 os. And will update you soon.
Albertt
Thanks for your sugesstion. Do you have Cisco XRv 9000 image file for eve-ng lab ?
