07-17-2014 12:20 AM
The PE to PE are already in place, MPLS/L3VPN. Now, we are going to deploy several CE routers. However, they are deployed in ring topology via fiber network. The routers we bought are ASR9006.
How can I deploy BGP for CE-PE, considering we do not have separate L2 network, CEN, or MSPP?
07-17-2014 02:06 AM
Request you to attach network diagram to make it more clear. If i am getting it correct all CE routers are connected in a ring and ring is getting terminated on PE. And each CE will be having LAN to connect end users. In this topology one CE will be used in data forwarding for other CE's customers and in case one port on PE goes down all traffic will transit from one CE directly connected to PE. This may cause high CPU. Please share clear requirement of your design.
- Akash
07-20-2014 10:22 PM
07-20-2014 10:30 PM
Establishing BGP between CE and PE is not a problem. You can have multi-hop eBGP between CE loopback and PE loopback or you have establish eBGP between PE and directly connected CE and then iBGP between CEs. But my only concern is that one CE will act as transit for other CE. Cant we have DWDM ring on layer 2 and connect CE to DWDM ring. What device you are using as CE and how much traffic is expected on that ring.
-Akash
07-20-2014 11:48 PM
Unfortunately, there will be no DWDM on access or aggregation rings. ASR9006 for access rings, and ASR9010 for aggregation rings. All fiber will terminate directly to routers. Is it possible to establish L2VPN sitting below BGP in these equipment? Is this advisable?
07-21-2014 12:05 AM
for setting up L2VPN between CE and PE, requirement not clear to me. Depends what services you are offering to end customers. If they are using just internet service, to get full/partial/default route BGP should be sufficient and any IGP protocol you can run for reachability to BGP next-hop
07-21-2014 12:28 AM
Hello Akash,
The network will be solely for wireless service provider network (2G/3G). There will be no external customers. Node at the CE premises will communicate to elements at Core location (Data Center), and there will also be nodes at CE which will directly communicate to other CE nodes. There are numerous VRFs, and 2 or 3 Data Centers.
